Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13487 Discussions
NUC6i3SYK - Machine check exception - no boot
RKnal
Hi!
For the past eight weeks, I have been happily running a NUC6i3SYK with Xubuntu 15.10 as a media player/HTPC. Memory modules are 2 x 4GB Crucial CT4G4SFS8213 DDR4-2133 and SSD is a Transcend TS128GMTS800. BIOS version is 0028.
Everything has been fine, no problems whatsoever regarding software or hardware. The machine has been running 24/7 for the last about 4 weeks.
Recently, the machine hung itself, and when rebooting, it enters the GRUB menu. From there trying to boot normally into Linux results in a reboot, ending once more in the GRUB menu. The same happens when rebooting in recovery mode, however, it get a bunch of messages prior to reboot, the final ones of which read as follows (timecode removed):
mce: [Hardware Error]: CPU 3: Machine Check Exception: 5 Bank 6: be0000000008117a
mce: [Hardware Error]: RIP !INEXACT! 10: {intel_idle+0xbe/0x120}
mce: [Hardware Error]: TSC 5f6c9367e8 ADDR 2677b5580 MISC 372e02c086
mce: [Hardware Error]: PROCESSOR 0:406e3 TIME 1455929507 SOCKET 0 APIC 3 microcode 57
mce: [Hardware Error]: Run the above through 'mcelog --ascii'
mce: [Hardware Error]: CPU 1: Machine Check Exception: 5 Bank 6: be0000000008117a
mce: [Hardware Error]: TSC 5f6c9367dc ADDR 2677b5580 MISC 372e02c086
mce: [Hardware Error]: PROCESSOR 0:406e3 TIME 1455929507 SOCKET 0 APIC 2 microcode 57
mce: [Hardware Error]: CPU 2: Machine Check Exception: 5 Bank 6: be0000000008117a
mce: [Hardware Error]: TSC 5f6c936860 ADDR 2677b5580 MISC 372e02c086
mce: [Hardware Error]: PROCESSOR 0:406e3 TIME 1455929507 SOCKET 0 APIC 1 microcode 57
mce: [Hardware Error]: CPU 0: Machine Check Exception: 5 Bank 6: be0000000008117a
mce: [Hardware Error]: TSC 5f6c936870 ADDR 2677b5580 MISC 372e02c086
mce: [Hardware Error]: PROCESSOR 0:406e3 TIME 1455929507 SOCKET 0 APIC 0 microcode 57
mce: [Hardware Error]: Machine check: Processor context corrupt
Kernel panic - not syncing: Fatal Machine check
Kernel Offet: disabled
What I did so far is:
1. Run IPDT for UEFI, showing no errors, but a warning to the effect that the clock speed is too high (3 GHz). I did not do any overclocking or the like.
2. Run Memtest86 for each memory module separately, four full passes, showing no errors.
3. Tried to boot into various live images (Knoppix 7.0, Xubuntu 15.10, IPDT under Fedora, SystemRescueCD), however, the system hangs itself at some point during boot.
BIOS has been reset to standard values prior to the above.
What I will do next is put the SSD into my PC and run some checks on it. However, since I cannot boot any live images, I do not think it is a SSD/file system-related error.
So, does somebody have any ideas what might be the problem and what I might do to solve it (short of getting a replacement unit)?
Thanks, Robert
JSpig
I had the same thing on a NUCi5SYK. I may have a partial solution. In the BIOS, From default settings, I disabled the Performance > Intel Turbo Boost Technology.
I can now boot the system. Trouble is, I'm still getting kernel panics every few hours which I'm still troubleshooting...
RKnal
Thanks! I will try that and report back.
RKnal
OK, seems like the i3 doesn`t even have Turbo Boost. However, I tried to set all processor related settings in the BIOS to basic functions, to no avail...
SKell7
New Contributor III
I did what the log said and ran it through mcelog --ascii:
Hardware event. This is not a software error.
CPU 0 BANK 6 TSC 5f6c936870
RIP !INEXACT! 10:ffffffff814559fe
MISC 372e02c086 ADDR 2677b5580
TIME 1455929507 Sat Feb 20 01:51:47 2016
MCG status:RIPV MCIP
MCi status:
Uncorrected error
Error enabled
MCi_MISC register valid
MCi_ADDR register valid
MCA: corrected filtering (some unreported errors in same region)
Generic CACHE Level-2 Eviction Error
STATUS be0000000008117a MCGSTATUS 5
CPUID Vendor Intel Family 6 Model 78
RIP: intel_idle+0xbe/0x120}
Seems like a hardware error of the 2nd level cache (or the 3rd level cache or RAM as it is an eviction error). But who knows. Maybe intel_idle does something to the P-State / C-State which the CPU doesn't like. I have never had MCEs due to software, though. I think it more likely that the CPU is defective and you should RMA it.
JSpig
I guess my solution above was off the mark - mine NUC has started throwing the Fatal Machine Check errors again... I even have tried to boot to a USB key with the Intel Processor Diagnostic Tool Live OS and can't run the tool because the error comes up before I get the chance to run the tool.
Might have to try getting an RMA.
RKnal
I also couldn`t boot into the Fedora-based IPDT, however, there is a UEFI version that I was able to boot.
n_scott_pearson
Super User Retired Employee
This sounds more like an issue with the memory. Have you tried running with a different DIMM installed? I would do so...
RKnal
I haven't tried different DIMMs, but as I said, Memtest results in no errors for both modules. Further, the problem persists when using only one module at a time for both modules.
Therefore, I think it is rather unlikely that it is a memory issue...
Did you end up having to RMA the unit, rk75muc? I'm experiencing similar errors: memtest runs fine, but I can't boot into nearly any operating system without a kernel panic and a reboot.
RKnal
Yes, I had to RMA the unit which went suprisingly fast and easy. New unit works perfectly until now with the old memory modules and old SSD. To be on the safe side, I put cooling in BIOS to "cool".
Amy_C_Intel
Hello, All:
Thank you very much for your feedback.
rk75muc, so the unit works fine now?
RRako
"I put "cooling in BIOS to "cool" " - rk75muc - don't play with devil !!!
RKnal
Amy: Yes, the unit works fine for now.
rado: Well, I figure "cool" is the most hardware-friendly setting, right?
RRako
Yes but nobody knows yet if changing things regarding cooling fan can cause fan stop issue
Amy_C_Intel
rk75muc, thank you for sharing that. Let me know if the if the unit continues to work fine.
I'm sorry but I can confirm the problems withe the NUC.
My NUC6i5SYH is equiped with 2x4 GB RAM and a 250 GB SSD and running Windows 10 - 64.
It works fine for about 4 weeks - 3D-CAD and some office jobs.
But yesterday it stops with windows error message WHEA_UNCORRECTABLE_ERROR ... and reboots ... and error ... and reboots ...and error ...
Trying to boot a linux system I got the same results as rk75nuc reported ... :-(
Klaus.
RRako
And which version of BIOS do you have?
Setup is running, so I can get the bios version:
SYSKLi35.86A.0028.2015.1112.1822
Default settings have been used.
RRako
So that's why you got this WHEA error, because you are on BIOS 0028 instead of newest 0042. Your HW is now physicaly damaged
Thanks for the quick diagnosis. It's very helpful to save additional investigations.
But I'm disappointed by the absence of an information to avoid the short lifetime of the NUC of only 4 weeks.
Mid of March I bought the NUC including a bios which is known as object to reduce the NUC to a device with inbuilt obsolescence.
The box contains a quick setup guide, regulatory and safety informations. But there was no hint or label to update the bios before use.
What's the recommendation to replace the damaged NUC?
