Intel assistant detected an update for the Realtek included on NUC6i5SYB. I downloaded the suggested driver, ran the install, Installshield removed the precedent version... The process continued and ended with an error "no driver found". Where can I download the previous version of the audio driver ? Before this install everything was running smoothly, now I can't work anymore...(I use MS Teams everyday for audio and video meetings !)
Board version: H81131-503
BIOS: SYSKLi35.86A.0065.2018.0103.1000
Alex
Use the "have disk" method to install the driver.
Doc
It's best practice to keep backups of installation archives for driver versions you have currently installed. Maybe keep even older driver versions, so you're always able to roll-back to a previous driver, if needed.
the intallation archive you are looking for is AUD_Win7_8.1_10_6.0.1.7982.zip and its filesize is 379.594.552 bytes
SHA256 checksum: 614c623e86c44ecb03578a2293270783d3b116dd2027211f9744c1670164fb33
the search engine duckduckgo.com reports a Swedish site (2nd hit) that has this driver available for download.
I downloaded this file and it did match my local copy.
