Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor II
NUC6i5SYH - Remote Control does not work
Jump to solution
Hello everyone,
I come back here, now to try to solve a problem found in my NUC.
I have a standard MCE remote control with a USB extender that works perfect with a Zotac Nano minipc, but I can't get it to work with NUC, using or not the extender.
I would like guidance on how to enable the feature.
I'm using BIOS 057. Will it be necessary to install some program in Windows 10 so that the remote control is activated?
Thank you.
Tags (1)
Accepted Solutions
Highlighted
I have a similar setup. To get the USB infrared to work I had to disable the built-in infrared in BIOS and uninstall the NUC CIR drivers. Next, plug in the USB, install the drivers provided with your USB extender -- and you should be good to go.
My USB extender simply wouldn't work with the NUC CIR enabled in BIOS.
Highlighted
Community Manager
CarlosLima: Thank you very much for getting in contact with the Intel® NUC communities. We are sorry to hear the NUC is not working as expected.
There is a newer BIOS version available in our web site, it is version 0061, we can try to install it using the F7 method in order to try to fix this problem:
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005850.html https://www.intel.com/content/www/us/en/support/boards-and-kits/000005850.html
https://downloadcenter.intel.com/download/26841/BIOS-Update-SYSKLi35-86A-?product=89190 https://downloadcenter.intel.com/download/26841/BIOS-Update-SYSKLi35-86A-?product=89190
I also found a link that says that the standard MCE remote control is included and was tested with the Zbox Nano AD10 Plus, so the remote control might not be fully compatible with a different NUC model, this could be just a compatibility situation:
https://hothardware.com/reviews/zotac-zbox-nano-ad10-plus-u-mini-pc https://hothardware.com/reviews/zotac-zbox-nano-ad10-plus-u-mini-pc
On the link below you will find the tested peripheral for your NUC, where you can find some remote controls listed under "Multimedia Devices":
https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-nuc-kits/000016218.html https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-nuc-kits/000016218.html
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Alberto R
Highlighted
Highlighted
New Contributor II
Hi jrhunt
Your tip was of great use, because in fact, I followed your guidance and the usb remote control extender worked perfectly.
I just disabled the infrared BIOS and did not delete the NUC CIR driver.
Many thanks for your tip.
Alberto R, considering the solution to the problem, I believe it is worth adding the Zotac remote control as a NUC6i5SYH compatible device, as long as it is disabled in the NUC BIOS.
Highlighted
Community Manager
arlosLima: Thank you very much for sharing that information. Perfect, it is great to hear the Zotac remote control is working now and we really appreciate your feedback about this matter.
Thank you very much to jrhunt for the information provided above.
Alberto R
