Community
cancel
Showing results for
Search instead for
Did you mean:
SKora1
NUC6i5SYH won't power on
I have a Intel NUC NUC6i5SYH which is not powering on. None of the LEDs light up even if pressed for a 2-3 sec.
The warranty of this device is valid till September 2019 but I am unable to create a warranty claim. Is there any solution to get this device fixed either by Intel or other means of support?
LeonWaksman
Try to contact by phone your local service center (Sri Lanka?) https://www.intel.com/content/www/us/en/support/contact-support/apac-contact.html
Leon
LeonWaksman
  1. Have you checked the Power Supply? Or, using other Power Supply?
  2. Try to press little harder on the POwer Button. There are problems with contaminated contacts of the Power Switch in this model.
Leon
