Community
cancel
Showing results for
Search instead for
Did you mean:
Molenhuis
NUC6i5syh death after failed bios update sy0073.bio
Jump to solution
Hello, I had troubles with updating my NUC. It had bios version sy0071. After I tried to update without the yellow jumper (every other step fails) it look good, but at the end of te proces I got a message that the update failed. I powered off with te button and after that it only turns on, with only te green led on the mainboard but nothing happens. I don't have a power led or screen. I don't no what to do to solve it.
Accepted Solutions
n_scott_pearson
Super User Retired Employee
That's good to hear. Mark a post as providing the solution for your question so that the intel Customer Support folks knows that the conversation can be closed.
Maria_R_Intel
Hello Molenhuis,
Thank you for posting on the Intel* Community.
Unfortunately, due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) helpful to address your request.
Maria R.
n_scott_pearson
'Update failed' - How did it fail? What did it say? Can you repeat and capture a picture of the screen with your phone? At every power off point, are you unplugging the power supply? If not do that too.
Molenhuis
Hello, thanks for your reply.  I was running bio sy0071. I tried to update to sy0073 on the different ways, but every update failed. So I tried to update without the yellow jumper and it was running well but at the end of the update proces, it came with an error that the update failed. I have forgotten te make a picuture. I powered off the nuc en when I powered on, nothing happened, I heard the fan running. After that, I removed all te memory, ssd etc, without succes. After that I removed also the battery for moren than 8 hours. All the action done without power, but evertything I tried nothing happened. On the board there is a green led en can push the power button, but no blue or orange light, no video, etc. I tried also different usb with the bios but no succes. Before the update the nic was running well.
n_scott_pearson
The green LED is just an indication that the power supply is provided standby power. It is the Blue Power LED that we want to see action on.
Try doing the jumper-based BIOS Recovery operation again. When it completes, if it says it failed, take a picture of the screen and post it here.
BTW, initial test should be,
  1. Remove memory. Power on. Should see Blue LED flash three times. If it does not, unit has failed (this could be caused by BIOS corruption).
  2. If it flashes three times, power off, reinstall the memory and power back on. Blue LED should come on solid (no flashes). If it does not come on at all, check for no-press on power button (i.e. check if button mechanism from lid is not pressing the actual button on the board). If it comes on and flashes, it means there's a problem (three flashes, for example, indicating bad memory).
Molenhuis
Hoi Scott,
thanks, I removed de memory, power on, but no blue or orange led. I think it is bios corruption. I don't have video and connected the nuc on another keyboard and monitor but no difference.
greetings John
Molenhuis
I remember that when I did the bios upgrade I got the error something like Intel Management Engine failed
n_scott_pearson
Well, that would do it. If the BIOS and ME firmware end up out of sync, they will not work together and the system will never POST. What is strange is that the ME is always updated first and, if it fails, the remainder of the firmware is simply not installed (so that they stay in sync). I hate to say it, but if this is what happened, there may be no recovery from this situation.
Molenhuis
Hello, I have another NUC6i5syh running on bios version syskli35.86a.0042.2016.0409. I tried to update it to version 0072 and 0073 but I get the error (0x800000000000015, 0). Hopefully someone can help me how to correct this erro.
n_scott_pearson
42 to 73 is a pretty big jump. I suggest that you do this using the BIOS Recovery by Security Jumper process. This is documented here: Intel NUC BIOS Update and Recovery Instructions.
Hope this helps,
Molenhuis
Hi mr. Scott, I have just successfully upgraded from 42 to 73 with your suggestion. Thanks very much!
n_scott_pearson
