Intel® NUCs
12512 Discussions
NUC6i7KYK SODIMM 1 slot not working after BIOS update
raduzamfir
I have an older model model (NUC6i7KYK) where after the BIOS update to v.0074 the SODIMM slot 1 (lower slot) is not working anymore.
I have 2x CT16G4SFD824A 16GB DDR4 RAM modules, and both work fine if only one is in the SODIMM slot 2. I used the same RAM modules prior to the BIOS update and it worked without any issues.
Once I connect something in slot 1 the PC is not booting anymore, after a few seconds it is just rebooting.
The display is not turning on, so I cannot access BIOS to see what is going on.
There is a solved post with the same issue but for a different (newer) model.
Alberto_R_Intel
raduzamfir, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, just to let you know, Intel® NUC Kit NUC6i7KYK is under the status of End Of Interactive Support / Discontinued as you can verify in the following link, where you can also see the memory specifications as well:
https://ark.intel.com/content/www/us/en/ark/products/89187/intel-nuc-kit-nuc6i7kyk.html
So, Intel® technical support will no longer be provided for this kind of product, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products Website helpful to address your request:
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Albert R.
