Community
cancel
Showing results for
Search instead for
Did you mean:
NUC7 Front panel header LED current
Jump to solution
Hi all,
we're using a NUC7 in a casing, so are implementing a remote button to turn it on and off. This button has a built-in LED, operating at 5V and 65mA max.
Is this too much for the header? I found the pins for the LED supply 5V in the TPS, but nowhere do they speak of the max current to draw.
Can anyone supply us with some more info? 🙂
Thanks!!
Accepted Solutions
Highlighted
Re: NUC7 Front panel header LED current
Jump to solution
Hi RogerVc,
For the front header LED pin, the maximum current draw is 0.5A and Voltage is +5V.
I hope this helps,
Ronny G
Highlighted
Community Manager
Jump to solution
Hi RogerVc: We will do our best to try to provide the information you are looking for.
In regard to your inquiry, we will do further research on this subject, as soon as I get any updates I will post all the details on this thread.
Alberto R
Highlighted
Jump to solution
Hi RogerVc,
I hope this helps,
Ronny G
Highlighted
Jump to solution
Great, that's clear! Thank you! (A resistor solved it ;-))
