Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11977 Discussions
NUC7CJYH1 no bootable devices
Community Manager
No matter what format or USB drive I cannot get one to boot. I have used actual windows 10 media creator tool and it will not boot on the NUC. I have tried Rufus also with no luck. I partitioned and formatted the drive with GPT and it still won't boot from the flash drive . Unsure of what to do
Community Manager
Hello Jmz,
Thank you for joining the Intel Community Support.
First, you can start by setting BIOS settings to default by pressing F9. Save the settings and exit.
Second, restart the unit and access the F10 menu when the splash screen shows up. Please take a picture of the options available and attach it to the thread.
Also, please provide the BIOS version installed.
Wanner G.
Community Manager
The device listrd on the boot menu is not my flash drive. That option shows up even if all devices are removed. Also if I change os from Windows to Linux in the BIOS the settings aren't saved after choosing save and exit in the bios . It seems hit or miss what settings are saved
Community Manager
Hello Jmz,
Thank you for your response.
Is Legacy Boot enabled? Make sure it is disabled, restart your unit, and try booting from the thumb drive again.
I also recommend you to perform a BIOS recovery. You can follow the instructions on the link below under the BIOS Recovery by the Power Button Menu section.
https://www.intel.vn/content/www/vn/vi/support/articles/000005532/mini-pcs.html
Also, please find the Recovery BIOS file below:
https://downloadcenter.intel.com/download/27563/BIOS-Update-JYGLKCPX-86A-?product=126135
Additionally, just for testing purposes, use a different operating system image or version to check if the thumb drive is detected.
Wanner G.
Community Manager
Legacy boot is off. I have tried Windows and Linux installers and multiple USB devices. I have already tried the BIOS recovery.
Community Manager
Hello Jmz,
Are you able to boot from the flash drive in another unit/system?
Wanner G.
Community Manager
Yes on every other device in the house
n_scott_pearson
Super User Retired Employee
Try completely clearing the Secure Boot configuration and then, if it isn't already, disable the feature. Can you then see the devices?
Community Manager
If I disabled it, save and reboot it doesn't stay disabled
n_scott_pearson
That's why I said clear its configuration.
Community Manager
Yes and that doesn't change my issue
n_scott_pearson
In Visual BIOS, click on Advanced then Devices and Peripherals and then on the Onboard Devices tab. Are both the LAN and WLAN entries in the (left-hand) Onboard Device Configuration window enabled (checked)?
Community Manager
Mitchell_R_Intel
Looks like BIOS 0037 is available. You might try flashing that onto your NUC to see if the problem goes away. I tried my JYH NUC and it seems to function correctly. You may have a bad NUC. If the BIOS update does not work, contact Customer Service for a replacement unit.
Also, what revision of the EC firmware and TXE firmware does yours have? It is displayed on the Home page 2nd Dot. Mine is: EC FW: 02.23, TXE FW: 4.0.0.1242.
n_scott_pearson
That's good advice from Mitch. If, after installing BIOS 37, the firmware revisions do not match, I recommend that you reinstall BIOS 37 using the jumper-based BIOS Recovery method. After doing so, remember to go into BIOS Setup and use F9 to reset the BIOS configuration to defaults.
Community Manager
Ok, so downloaded new BIOS and put on flash drive. Held power button for three seconds and all I get is power button flash 3 times and a pause and repeat. Pull bios jumper and boot it up and I get the menu and press f4 and it immediately says power off and replace the jumper and turn back on. Updating in bios says error updating capsule.
Mitchell_R_Intel
You don't hold the power button down for 3 seconds when the recovery jumper has been pulled. The system will boot to the recovery menu or the BIOS recovery countdown automatically.
Community Manager
Yes I know. Each sentence is a different attempt
Mitchell_R_Intel
Did you do a low level format of your flash drive as a FAT32 formatted drive and not a quick format? This tends to be more compatible with BIOS recovery. Also, make sure you only have one BIO file in the root of the drive. Multiple BIO files will cause the recovery to fail.
Community Manager
Raw formatted to every Windows format with no change. Fat32, fat, ntfs, exfat. They all result the same. These are fresh newly partitioned drives with no other files on them
Mitchell_R_Intel
But did you do a quick format for all those drives? That is the issue. I have found that doing a slow low level format (can take a long time to format depending on the size of the drive used) gives you a better chance of the drive being detected properly. I know it sounds strange but it does work for some reason.
