Community
cancel
Showing results for
Search instead for
Did you mean:
CMidd
NUC7I3BNH uhd colour problems
Hi I've got a NUC7i3BNH hooked up to my Samsung MU7000 4K TV. When I enable UHD colour the graphics on my NUC play up i get screen flickers and also white pixels in the display. Ive got all the lastest drivers installed and tried different HDMI cables. as soon as I dIsabe UHD colour everything is back to normal.
Callum
Tags (1)
Community Manager
Hello Callum1983,
I understand that your unit is giving you screen flickering and white pixels on the display when you turn on UHD color.
Regarding this, to better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
CMidd
Hi I hope this is ok
System Information
Time of this report: 3/5/2018, 22:38:45
Machine name: DESKTOP-NRHMR7B
Machine Id: {50F6FFA1-4C4D-49AC-BADC-AC2C4A451682}
Operating System: Windows 10 Home 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
Language: English (Regional Setting: English)
System Manufacturer:
System Model:
BIOS: BIOS Date: 02/22/18 16:44:56 Ver: 05.0000C
Processor: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8076MB RAM
Page File: 1979MB used, 8015MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 288 DPI (300 percent)
System DPI Setting: 288 DPI (300 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.16299.0015 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 620
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_5916&SUBSYS_20688086&REV_02
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 4165 MB
Dedicated Memory: 128 MB
Shared Memory: 4037 MB
Current Mode: 3840 x 2160 (32 bit) (59Hz)
HDR Support: Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.659680,0.340344), Green(0.244641,0.670422), Blue(0.130383,0.040539), White Point(0.313000,0.329602)
Display Luminance: Min Luminance = 0.010000, Max Luminance = 1499.000000, MaxFullFrameLuminance = 799.000000
Monitor Name: Generic PnP Monitor
Monitor Model: SAMSUNG
Monitor Id: SAM0DEF
Native Mode: 3840 x 2160(p) (60.000Hz)
Output Type: Displayport External
Monitor Advanced Color Capabilities: BT2020RGB BT2020YCC Eotf2084Supported AdvancedColorSupported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Driver Name: C:\Windows\System32\DriverStore\FileRepository\ki126218.inf_amd64_b758f45a509290e3\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\ki126218.inf_amd64_b758f45a509290e3\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\ki126218.inf_amd64_b758f45a509290e3\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\ki126218.inf_amd64_b758f45a509290e3\igd12umd64.dll
Driver File Version: 23.20.0016.4901 (English)
Driver Version: 23.20.16.4901
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.3
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 18/12/2017 00:00:00, 50409624 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-1A56-11CF-13F0-7800B9C2DA35}
Vendor ID: 0x8086
Device ID: 0x5916
SubSys ID: 0x20688086
Revision ID: 0x0002
Driver Strong Name: oem7.inf:5f63e534fccdbc6c:iKBLD_w10_DS:23.20.16.4901:pci\ven_8086&dev_5916&subsys_20688086
Rank Of Driver: 00D10001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
XXXWHITESPA...
Community Manager
Hello Callum1983,
Thank you for your response,
The first thing that we must address as a testing step is to download and install the latest graphics driver available for your graphics controller. Please refer to the following link:
https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?pr... https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?pr...
Please download the ".zip" file and follow these steps:
1 - Unzip the file to a designated location or folder.
2 - Right-click Windows Start icon and open Device Manager.
3 - Click Yes when prompted for permission from User Account Control.
4 - Expand the Display adapters section.
5 - Right-click the Intel® graphics entry and select Update Driver Software.
6 - Click "Browse my computer for driver software".
7 - Click "Let me pick from a list of device drivers on my computer".
8 - Click "Have Disk".
9 - Click "Browse".
10 - Access the designated location or folder, and access a folder called "Graphics".
11 - Select the file called "igdlh64" or "igdlh".
12 - Click Open, then click OK, and finally click Next. Drivers are now being installed.
13 - Reboot your computer
David V
CMidd
Hi that driver you sent me won't install on my NUC7I3BNH it says it's not compatible.
isnt this the lastest graphics driver for my NUC
https://downloadcenter.intel.com/download/26947/NUCs-Intel-HD-Graphics-Driver-for-Windows-10-for-Int... Download Intel® HD Graphics Driver for Windows® 10* for Intel® NUC Kit NUC7i3BN, NUC7i5BN, and NUC7i7BN
Community Manager
Hello Callum1983,
The latest driver for your graphics controller is the one provided in the link above. In this case if it gives you an error when trying to install it then the steps provided must be followed in order to properly update the driver. Make sure to download the ".zip" file and not the ".exe" one please.
9 - Click "Browse".
If after these steps you get an error, please attach a screenshot of it so I can have a look and investigate.
David V
CMidd
Managed to install the attached driver you ask me to with no luck same issues
spent a few hours trying differnt things heres my findings.....
with the UHD colour setting on my TV enabled and My resolution set to 30hz I get no flicker, no cracking sound and no flashing pixels and everything seems to work fine.
When i increase the resolustion to anything higher like 50 or 60hz i get screen flicker, flashing pixels, cracking sound and even BSOD.
Ive tried rolling back display driver and even the bios with no luck what so ever. I've attached a close up of the flashing pixels
Community Manager
Hello Callum1983,
After checking the information you sent and doing some more research I was able to find two things we can try and see if it fixes your current problem.
First, I would like you to completely disconnect the HDMI cable from the TV. Turn off the UHD Color and then back on, wait around 10 seconds and then plug the HDMI cable back in, if possible connect it to the HDMI 1 port. If after this steps the problem persists then please do the following:
1 - Open the "Graphics Properties" by right-clicking on the desktop.
2 - Click on Display
3 - Click on "Color" and look for the option "YCbCr". If it is enabled then disable it. If it is disabled then please enable it.
4 - Apply the changes and let us know the outcome.
David V
CMidd
Hi just tired both of the things you have just suggested with no luck.
This is thing has never had stable drivers and full resolution from day one :-(
Regards Callum
Community Manager
Hello Callum1983,
Since you have tried the different troubleshooting steps to no avail, I would like you to fill out the information requested in the following thread:
/thread/77761 https://communities.intel.com/thread/77761
Please fill out the information and post it here so we can look into this problem and see what could be causing it. I apologize for any inconveniences.
David V
CMidd
Thanks for your reply
Sorry Im not happy with all this "faffing" about the unit has never been able to display its full resolution as it was advertised to me. Please can you direct message me to discuss returing it
callum
Community Manager
Hello Callum1983,
I was reviewing all of the information and everything we have been discussing thus far and I after some investigation and testing I determined that the type of HDMI cables that you have been using are 1.4 and not the 2.0.
The HDMI* cable must be a 2.0 cable as this is what is needed for the video to display properly on 50Hz and 30Hz. I also determined that even the user manual of the TV mentions that the resolution is supported on HDMI 2.0.
As a testing step I would recommend you to try to connect the Nuc to the TV with an HDMI 2.0 cable. For more information of what is supported please refer to the user manual of your TV. Also, I have attached a picture of the chart where it shows the resolutions. You can also refer to the link below:
http://downloadcenter.samsung.com/content/UM/201801/20180123102314699/ENG_US_KTMATSCL-3.0.8.pdf http://downloadcenter.samsung.com/content/UM/201801/20180123102314699/ENG_US_KTMATSCL-3.0.8.pdf
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
David V
CMidd
Hi thanks for your reply
ive been using a Philips 4k 2.0 HDMI cable which plays perfect 4K HDR on my Apple TV and Nvidia shield TV. I'm certain this unit is faulty I've tried everything including a windows memory test which indicated a hardware fault. Even My local computer shop reckons its fauly hardware
Callum.
Community Manager
Hello Callum1983,
I have sent you a private message.
David V
CMidd
Got a replacement unit yesterday. Install windows and updated all the drivers still having the same issue. Even the bios screen is show flashing pixels.
Very Frustrated
Community Manager
Hello Callum1983,
Thank you for your response.
I understand that your system is still not functioning properly even after the replacement was done. I would like to confirm the current versions of driver and BIOS, please attach a DxDiag report of the new acquired unit. Please follow these steps:
In the meantime I will also need you to provide me with the model of HDMI* cable you are using, as well as any other cables you may have tested, if you have not tested other cables then make sure to connect the NUC to the TV in the HDMI port 1 with the cable(s).
Let me know the information and the outcome please.
David V
CMidd
Hi thanks for your repy heres the DXDiag as requsted
System Information
Time of this report: 6/18/2018, 21:39:27
Machine name: DESKTOP-MHP0QEO
Machine Id: {AAEDD3CF-7C77-44B9-B923-C78C61DCF3C5}
Operating System: Windows 10 Pro 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
System Manufacturer: Intel Corporation
System Model: NUC7i3BNH
BIOS: BNKBL357.86A.0064.2018.0529.1711 (type: UEFI)
Memory: 8192MB RAM
Page File: 2870MB used, 6485MB available
Windows Dir: C:\WINDOWS
DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
Display Devices
DAC type: Internal
Device Type: Full Device (POST)
Current Mode: 3840 x 2160 (32 bit) (60Hz)
HDR Support: Not Supported
Color Primaries: Red(0.641125,0.330578), Green(0.301281,0.601086), Blue(0.150891,0.061047), White Point(0.280773,0.290539)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Id: SAM0DEE
Native Mode: 3840 x 2160(p) (30.000Hz)
Monitor Capabilities: HDR Not Supported (Eotf2084Supported )
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_5e08b58c3b8f75d0\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_5e08b58c3b8f75d0\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_5e08b58c3b8f75d0\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_5e08b58c3b8f75d0\igd12umd64.dll
Driver File Version: 24.20.0100.6025 (English)
Driver Version: 24.20.100.6025
DDI Version: 12
Driver Model: WDDM 2.4
Miracast: Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:False
Driver Date/Size: 4/25/2018 1:00:00 AM, 2037712 bytes
WHQL Logo'd: Yes
Device Identifier: {D7B78E66-1A56-11CF-BFF4-0C00B9C2D535}
Vendor ID: 0x8086
Device ID: 0x5916
Revision ID: 0x0002
Driver Strong Name: oem34.inf:5f63e534fccdbc6c:iKBLD_w10_DS:24.20.100.6025:pci\ven_8086&dev_5916&subsys_20688086
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeVP8_VLD DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch...
Community Manager
Hello Callum1983,
Thank you for your response and the information provided.
I can see that there is an available update for your graphics controller. Let us start by attempting to install this update, please go ahead and download the ".zip file" located in the link below:
https://downloadcenter.intel.com/download/27847/Graphics-Intel-Graphics-Driver-for-Windows-10?produc... https://downloadcenter.intel.com/download/27847/Graphics-Intel-Graphics-Driver-for-Windows-10?produc...
After the download, please follow the steps below:
9 - Click "Browse".
11 - Select the .INF file (Setup information).
Once this is done, please turn on the UHD color on the TV and test it. Is the "HDR" option under "settings" of your Windows* turned ON or OFF? If it is OFF, then please attempt to turn it ON.
Let me know the outcome.
David V
CMidd
Hi thanks for your reply I've tried this driver with no luck. Also tried the driver in the NUC7I3BNH support page.
Kind regards
callum
Community Manager
Hello Callum1983,
Up to this point, I will need to gather as much information as possible and run some testings myself. In order to do so, please access the link below and then provide me with all the information requested there:
Post all of the requirements and information requested in this thread. I will wait for the information.
David V
