Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11991 Discussions
NUC7I3BNH - windows 10 install on 2nd ssd
MBian2
hi all, i'm new on this forum and sorry for my english, hope its fine!
I'm about to buy a NUC7I3BNH, and i know there is a M.2 ssd slot and a second sata.
Can i use my evo ssd (non m.2) to install windows 10, not using the m.2 slot?
thanks
LeonWaksman
Yes you can. The Windows 10 can be installed on your 2.5" SATA SSD. You can use your NUC with M.2 slot empty.
However I suggest to you to buy M.2 SSD 250GB (for example this one: https://www.amazon.com/Samsung-970-EVO-250GB-MZ-V7E250BW/dp/B07BN5FJZQ https://www.amazon.com/Samsung-970-EVO-250GB-MZ-V7E250BW/dp/B07BN5FJZQ ) and use this drive as a System+Program drive. The access to storage drive is usually a bottleneck in computers. SATA SSD has write/read speed about 520 MB/s when Samsung 970 EVO has writing speed of 3500 MB/s and read 2500 MB/s.
So, the performance of you NUC will be much better, using M.2 NVMe drive for Windows and other programs, while the 2.5" SATA will be used for data storage (pictures, movies, documents,...).
Leon
MBian2
Thanks for the answer! I know m.2 is fast, but my evo 860 500gb ssd will be ok and not a bottleneck.
I'll use it for a hom server
LeonWaksman
O.K. , so, you can use only SATA drive and leave the M.2 slot empty.
Leon
