Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11991 Discussions
NUC7PJYH + Win10 USB = A media driver your computer needs is missing.
oshy
I have a NUC7PJYH.
I am having a trouble with installing Windows 10 on it from a USB drive.
It boots normally (I use front blue USB port), then when I click "Install Now" button I see this message:
A media driver your computer needs is missing. This could be a DVD, USB, or Hard disk driver. If you have a CD, DVD, or USB flash drive with the driver on it, please insert it now.
[Browse] [OK] [Cancel]
I need to make this step work.
I suppose, I should put some sys/inf files on a separate USB and feed it to NUC.
I have this bundle https://downloadmirror.intel.com/DriverPackages/Intel-NUC-Kit-NUC7PJYH_Win10-64_Drivers.20190311.zip with a dozen of MSI/zips in it, with hundreds of files in each.
Question: what files I should put on a separate USB to make Windows 10 installation proceed?
AlHill
Format your USB stick (that is 8gb or greater) ON ANOTHER PC (not a mac or linux machine).
Then, download W10 from here to create the install media on your USB stick:
https://www.microsoft.com/en-us/software-download/windows10
Then, boot your usb stick.
Make sure you are set for UEFI boot in the bios, and the stick is formated FAT32.
Doc
n_scott_pearson
Super User Retired Employee
Al is correct; there seems to be an issue with the default images from Microsoft. If you create one using the tool, it installs without issue.
Oh, and BTW, you do not need to have any of the drivers in the package available until after the Windows 10 install is complete.
oshy
Thank you, Al, Scott. You were right.
Once I switched to Rufus USB flasher, the problem disappeared.
n_scott_pearson
Aren't you glad we're here? We had to learn this the hard way...😭
