Community
cancel
Showing results for
Search instead for
Did you mean:
SMax
NUC7PJYH2 not booting
i brought today a NUC7PJYH2 with following compontens :
- 250GB Crucial MX500 2.5" (6.4cm) SATA 6Gb/s 3D-NAND TLC (CT250MX500SSD1)
- 8GB (2x 4096MB) HyperX Impact DDR4-2400 SO-DIMM CL14-14-14-29 Dual Kit
when i switch the nuc on i have a black screen and the blue light blinks 3 times after 1-2min the nuc turns off and boot again.
looks like an issue withe the ram.
is there any change to get run the system with this ram or i schould buy another ram ?
Tags (1)
n_scott_pearson
Super User Retired Employee
Test using a single SODIMM. Try it in both the upper and lower SODIMM slots. If neither test succeeds, switch to the other SODIMM and test again.
Let us know the results,
SMax
i testet with both SODIMMs in single Mode on each slots nothing happens same probs here.
n_scott_pearson
What's the full part number for the SODIMMs?
SMax
HX424S14IBK2/8
1,2V
DTMH0841813
LeonWaksman
If I guess correctly, you are using HyperX HX424S14IBK2/8: https://www.kingston.com/dataSheets/HX424S14IBK2_8.pdf https://www.kingston.com/dataSheets/HX424S14IBK2_8.pdf . If my guess is correct, each SODIMM is build from 8 SDRAM devices and the SDRAM density is 4Gbit (which is correct density for your NUC). However this memory wasn't checked by Intel.
Intel has checked similar kit made by HyperX: HX424S14IBK2/32 (2 X 16GB), also with correct parameters and this memory was found as incompatible: http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...… .
So, I'll suggest to test other memory taken from the above mentioned Intel list.
Leon
SMax
ok, i will test with another memory from G.Skill F4-2400C16D-8GRS
OWeis
You need ram with a CAS latency of 16 or more the G.Skills work fine i have these in my own PJYH.
PLerc
I have bought a NUC8, but wants to know if HX424S14IBK2/32 are not supported and stable?
LeonWaksman
Hello @PLerc​
NUC8 is not the complete model identification. Please describe the complete number. For example: NUC8i3BEH.
Leon
PLerc
Hi it's NUC8I3BEK
n_scott_pearson
Since this is a different NUC model, please open a new conversation (ask a new question)​ for your issue.
LeonWaksman
I agree with Scott. You should open a thread of yours. This will also helpful to other forum users.
Leon
PLerc
Believe me I would like to but am getting an error each time I try. Therefore I had to ask here.
LeonWaksman
Hi @PLerc​
  1. In this case that you can't open new thread I'll answer here for your question and report the problem to the Community Manager @MaryT_Intel​ .
  2. In my post above I've my statement about instability of Kingston memory HX424S14IBK2/32 was related to NUC7PJYH2. This reported by Intel here: http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
  3. I believe that this is not relevant for NUC8i3BEK. Intel didn't verified this memory kit (2 X 16GB), however, memory HX424S14IB/16 was validated for your NUC. You may find in this list all validated by Intel Mmeory modules for your NUC http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... . If some memory dosn't appears on this list, it doesn't mean that it will be not compatible. It means only that it wasn't tested by Intel.
Leon
PLerc
Thanks for the help and answer:)
