Community
cancel
Showing results for
Search instead for
Did you mean:
mjons
NUC7i3BNH- New changes in bios regarding led light?
I have the NUC7i3BNH that i have set led colour as orange and slowly pulse when in hibernation. When I put it in hibernation I see the orange light working, but after 15-20 minutes it is off,no light.
I have upgraded bios when available so maybe there's a new function I don`t know about?
Community Manager
marjo: Thank you very much for contacting the Intel® NUC communities. We will do our best to provide the information you are looking for.
In regard to your inquiry, I just wanted to let you know that we tested that same NUC in our lab and the issue was not replicated, the light never went off in hibernation. I also looked on the released notes for BIOS 0054, and there are no comments in regard to this matter:
https://downloadmirror.intel.com/27256/eng/BN_0054_ReleaseNotes.pdf https://downloadmirror.intel.com/27256/eng/BN_0054_ReleaseNotes.pdf
So, please try to re-install the BIOS version 0054 using the F7 method to try to fix this problem:
https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html
https://downloadcenter.intel.com/download/27256/BIOS-Update-BNKBL357-86A-?product=95066 https://downloadcenter.intel.com/download/27256/BIOS-Update-BNKBL357-86A-?product=95066
Any further questions, please let me know.
Alberto R
Community Manager
marjo: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
mjons
I did try the bios method again, it seems the led light works if put into hibernation by ir remote.
If the pc goes into hibernation by itself led light does not work. It is not a big deal if it works, but I will check the bios again if theres a missed setting.
n_scott_pearson
Super User Retired Employee
My suggestion would be to reinstall the latest BIOS, but this time using the jumper-based BIOS Recovery method.
Once the update is complete, use F2 to enter BIOS Setup (the Visual BIOS (VB) program). Press F9 (followed by Y) to reset The BIOS configuration. Then, press F10 (followed by Y) to exit VB with BIOS Configuration save.
During the subsequent POST, again press F2 to enter VB. Now make whatever BIOS Configuration changes, including LED programming, that you desire/require. Use F10 (followed by Y) to exit VB saving these changes.
Now test the Hibernation entry methods...
Note: do not combine the two BIOS Configuration change steps. The BIOS Configuration save and re-POST in between *is* important.
Hope this helps,
Community Manager
Alberto R
