Intel® NUCs
11772 Discussions
NUC7i3BNH and AOC USB Monitor
APand3
I want to buy NUC7i3BNH & a 15.6" Monitor. In AOC brand there is 15.6" monitor available but that is USB powered and also has VGA port. For the VGA, I can use HDMI to VGA converter. But, does this NUC deliver enough power to run a USB powered monitor along with Wireless keyboard/mouse running on single receiver and a printer? I think the monitor requires 5v power.
Akshay
Community Manager
Hi N!k: Thank you for joining the Intel® communities support.
In order to provide the most accurate response, could you please provide the model of the monitor?
In the following link you will find a list of tested peripherals, in there you will find some monitor models that were tested as compatible with the NUC:
http://compatibleproducts.intel.com/ProductDetails%3FactiveModule%3DIntel%25C2%25AE%2520NUC%23 http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC#
Alberto R.
APand3
Thank for your reply.
The model is E1670swu. It has a USB port for power and VGA port. Also would like to know if there is any model with pre-loaded RAM and hard disk for 7th generation i3 NUC that is available in India?
Community Manager
Hi N!k: You are very welcome, thank you for providing that information.
Yes, the Intel® NUC7i3DNHNC and NUC7i3DNKTC have the memory RAM pre-installed and one of them came with a HDD and the other one with SSD, as you can confrim in the following link:
https://ark.intel.com/products/147968/Intel-NUC-7-Business-a-Mini-PC-with-Windows-10-Pro-NUC7i3DNHNC
https://ark.intel.com/products/147969/Intel-NUC-7-Business-a-Mini-PC-with-Windows-10-Pro-NUC7i3DNKTC
We will do further research in order to confirm if the NUC is capable of supporting the wireless mouse and keyboard, the printer and the monitor.
Alberto R.
Under Contract to Intel Corporation
LeonWaksman
Hello Akshay,
1. NUC7i3BNH fits your requirements. In addition to regular blue USB 3.0 ports (900 mA max current), it is equipped with USB Type-C connector (maximum current is 3A) and USB 3.0 1.5 A orange charging port. See the technical Product Specification on page 28 for details: https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i3BN_TechProdSpec.pdf https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i3BN_TechProdSpec.pdf .
In the same specifications on page IV you will find description of different kit ready option for this NUC. For supply power to your 7W monitor, you should use the 3A Type-C port. The charging port is quite marginal (7.5W).
There is no problem to by compatible SSD, HDD and RAM for this NUC. See the list of tested and approved by Intel components: http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
2. The suggested in other post NUC7i3DNxx is not suitable for your needs, since it is equipped only with four 900mA ports.
Hope this helps
Leon
APand3
Thank you for your reply. I have found another workaround by using a AC to USB converter of 5v. In that case, it will act as standard monitor and also I can use the USB ports for other hardware.
Community Manager
Hi N!k: You are very welcome.
Perfect, excellent, it is great to hear that you were able to find a work around for this scenario.
Any other inquiry, do not hesitate in contact us again.
Alberto R.
