Community
cancel
Showing results for
Search instead for
Did you mean:
PNiek1
NUC7i3BNH and disabling xhci
Jump to solution
Hi there,
We have a bunch of NUC7i3BNH intended to be used in production for testing usb (2.0) devices. All NUCs run latest Ubuntu 16.04 LTS. When we connect a 49 port USB hub (which is a usb 2.0 hub) with about 40 devices connected to it, to a NUC, it "accepts" about 26 devices (+ a usb keyboard), creates devices in /dev/ as it should, but then complains:
[ 3867.140383] xhci_hcd 0000:00:14.0: Error while assigning device slot ID
[ 3867.142756] xhci_hcd 0000:00:14.0: Max number of devices this xHCI host supports is 64.
[ 3867.145013] usb 1-2.4.6-port2: couldn't allocate usb_device
So it seems we hit some sort of xHCI limitation. The solution I found on the internet is to disable xHCI mode in BIOS, so that linux would use slower eHCI mode/drivers, which support many more USB devices compared to xHCI. The problem is - there is no such option in BIOS.
I compiled a custom kernel (4.4.6) with disabled "xHCI HCD (USB 3.0) support" and left "EHCI HCD (USB 2.0) support" enabled, but NUC booted without any USB support at all, i.e. usb keyboard/mouse did not work, nor did the wired networking. Any solution to all this ?
Ronny_G_Intel
Hi big_nuc_user
NUC USB controller supports 128 end points and/or up to 64 devices, this is something you are already aware of it  [ 3867.142756] xhci_hcd 0000:00:14.0: Max number of devices this xHCI host supports is 64. Each USB device can have up to 16 end points so worst case if each device has 16 endpoints we would only support up to 16 devices.
We don't have any option in BIOS to disable xHCI, this was removed in later devices due to recent operating systems natively supporting USB3.0. and I would assume this NUC is purely xHCI as it provides interfacing for USB 1.x, 2.0, and 3.x compatible devices, I don't believe there is any other default back controller e.g. EHCI to run USB 2.0 devices.
Unfortunately I don't have any recommendation at this point to mitigate this issue as it seems to be a hardware limitation.
Ronny G
Community Manager
Hello big_nuc_user
Thank you for joining the community.
At this point due to of the peripherals nor being recognized you can try a clean installation of the operating system (OS), or get assistance from the Ubuntu community https://www.ubuntu.com/support/community-support https://www.ubuntu.com/support/community-support to restore the system to a point prior to the changes made on the kernel.
Leonardo C.
PNiek1
Hi Leonardo,
I can always boot back to stock kernel, so that's not a problem.
The problem, as I described in the first post, is that I'm getting a "Max number of devices this xHCI host supports is 64" error and there is no way, as far as I know, to disable xHCI (USB 3.0) in the BIOS.
By disabling xHCI and forcing EHCI, the NUCs would support many more USB devices. The question is how to do it. Why is there no BIOS option to disable xHCI ?
Community Manager
Hello big_nuc_user
Thank you for your response.
Could you let us know more information about the project that you have?
What are the models of the USB-hub and model of the USB devices you are testing?
Allow me to share with you that the options to disable xHCI is not available in the BIOS of the unit, but upon looking into the situation let me tell you that the unit has a USB header 2.0 on the board that could help you with your set up, refer to page 44 and 45 of the technical product specification (TPS) for Intel® NUC board NUC 7i3BNB on the following link
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i3BN_TechProdSpec.pdf https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i3BN_TechProdSpec.pdf
To use this USB header 2.0 you would have to get a USB 2.0 Panel Female Connectors to 10 Pin 2.0mm - 12 Inches please refer to the following link to check the product
http://www.gorite.com/2-usb-2-0-panel-female-connectors-to-10-pin-2-0mm-12-inches http://www.gorite.com/2-usb-2-0-panel-female-connectors-to-10-pin-2-0mm-12-inches
Please be aware that the content on that site is not controlled by Intel®. This information is offered for your convenience and should not be viewed as an endorsement by Intel® for the merchants or services offered there.
Hope this helps.
Leonardo C.
Community Manager
Hello big_nuc_user
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
PNiek1
Ok, here comes more info. This is the usb hub we are using: http://usb.brando.com/USB-49-Port-Hub_p12794c39d15.html USB 49-Port Hub
We connect 49 (usb 2.0) devices to the hub, and then connect the hub itself to one og usb3 (or event internal usb 2.0 port) to the NUC.
However out of 49 devices only about 26 devices are recognized before we start getting those error messages:
As I mentioned multiple times now, it seems like xHCI mode is the problem here, as it supports less devices then eHCI. Usually one can disable xHCI mode in BIOS, but there is no such option in the NUC BIOS.
Community Manager
Hello big_nuc_user
Could you provide us with the model of the power supply that is being used on the USB-HUB?
Have you tested if all the pots on the board are working properly?
Could you test the HUB on a desktop system? Does the system recognize all the devices?
Could you provide with the kind of USB 2.0 devices that are being tested?
Leonardo C.
Community Manager
Hello big_nuc_user
Leonardo C.
PNiek1
Corsair RM550x. This is just ordinary PC power supply, should not matter.
Yes, they are fine.
Yes, we have some A20-OLinuXino-LIME2 (using EHCI mode) which runs older debian os, and it recognises all 49 devices.
Video conferencing endpoints, which have usb serial port for debugging and configuration - that's the one we connect to USB hubs.
Community Manager
Hello big_nuc_user
Thank you for your response, I have sent you a private message, please review your private inbox.
Leonardo C.
PNiek1
I replied to the private message.
Community Manager
Hello big_nuc_user
I am going to investigate further in the case, I will be posting back as soon as news become available.
Leonardo C.
Ronny_G_Intel
Hi big_nuc_user
Ronny G
PNiek1
Hi Ronny,
so you are saying that even if I would find a way to disable xHCI driver in linux to force it to use EHCI, it wouldn't support more devices ?
Community Manager
Hello big_nuc_user
I am going to forward the case to the right department, for your better assistance.
Leonardo C.
Ronny_G_Intel
Hi big_nuc_user,
My assumption is that the NUC7i3BNH is xHCI only and that EHCI was not part of the implementation since xHCi is capable of USB 1.0/2.0 and 3.0. and Operating Systems validated to work with support USB 3.0 natively.
I think that if you disable xHCI, all USB ports would be disabled.
We have never tested this and this is not supported or validated, I am just assuming this should be the behavior based on the product specification, unfortunately I cant think of any other option to accomplish the amount of USB devices you want to connect.
I am going to do an extra consultation but if you dont hear from me over the next week it is because I was not able to find a workaround.
Ronny G
PNiek1
Thanks for the help Ronny. Could you tell me what is the latest NUC model which is NOT "xHCI only" ?
Ronny_G_Intel
I would say:
Intel® NUC Kit NUC5CPYH
Intel® NUC Kit NUC5PPYH
Intel® NUC Kit NUC6i3SYH
Intel® NUC Kit NUC6i3SYK
Intel® NUC Kit NUC6i5SYH
Intel® NUC Kit NUC6i5SYK
Intel® NUC Kit NUC6i7KYK
...please keep in mind and I am sorry to be repetitive but we dont provide support for this type of question as you already know this is not POR for any of the NUCs.
We are not responsible If the NUCs I listed above do not provide the necessary support for the amount of USB devices that you are trying to attach via the USB Hub, I am still consulting if there is any possible workaround though.
Ronny G
Ronny_G_Intel
Hi big_nuc_user,
I checked with some of my peers and upper escalation team but unfortunately I wasn't able to get any additional information other than what we have already chatted about.
Ronny G
