Community
cancel
Showing results for
Search instead for
Did you mean:
NViss
NUC7i3BNH dont start after a bios update to 60
Jump to solution
Last night i did a bios update, from 57 to 60 and when it was finished it showed "update succesful" and the nuc shut down.
but it didnt booted back up.
i tried to start the nuc by pressing the powerbutton but nothing happend.
it just dont boot anymore, all i got is a amber powerbutton and when i press it it turns of for a split second but the nuc dont start.
i have tried to:
change the ssd
change the memory
new hdmi cable
other output device (monitor)
clear my cmos
the nuc dont start so i cant flash back a older bios.
what i got is:
a amber powerbutton
power on the usb ports
and a green licht on the motherboard.
does someone knows what to try or is the nuc broke?
n_scott_pearson
Super User Retired Employee
Did you completely disconnect the unit's power (i.e. unplug power chord)? If not, do so for 15 minutes. You can combine with next step.
How did you attempt to clear CMOS? Did you disconnect the battery and power for 15 minutes? If not, try this.
Did you try powering on holding the power button down for 3 full seconds? If so, did you ever see the Power Button Menu?
If you remove the memory and power on, do you see the power LED flashing? If so, when you reinstall the memory and then power on, does the light go on solid or does it flash?
Hope this helps,
n_scott_pearson
Hope this helps,
NViss
disconeccting the battery did the trick.
thanx m8
