Community
cancel
Showing results for
Search instead for
Did you mean:
PSisk
NUC7i3BNH keeps restarting after BIOS update
Jump to solution
I have downloaded latest BIOS (v 61) and when update started, NUC keeps restarting all the time in about 60 seconds intervals (surprisingly once it started few days ago) . Screen (connected via HDMI) is blank, keyboard has all all LEDs off and mouse doesn't shine.
I have disconnected SSD - no change
if I remove memory, it indicates memory issue (power LED flashes 3 times)
CMOS reset doesn't help.
Is there anything I can do except applying warranty?
Thanks for help!
Petr (Siskin)
Accepted Solutions
Community Manager
Siskin: Thank you very much for contacting the Intel® NUC communities. We are sorry to hear the NUC is not working properly.
In this case what we can try is a BIOS recovery to 0061 by removing the jumper:
https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html
https://downloadcenter.intel.com/download/27416/BIOS-Update-BNKBL357-86A-?product=95066 https://downloadcenter.intel.com/download/27416/BIOS-Update-BNKBL357-86A-?product=95066
Did you test the NUC on different outlets?
Did you try to disconnect and re-connect the HDMI cable, keyboard and mouse?
Did you test it just with one memory stick?
Do you have the option to test the NUC with a different power adapter?
Any further questions, please let me know.
Alberto R
Community Manager
Alberto R
PSisk
Hi Alberto,
thank you very much, BIOS recovery helped and problem is solved
Siskin
