On bios 0057 and graphic driver 4849 all work fine, and HDR works.
After update to bios 0061 and graphic driver update 4877, screen flashing and no HDR work.
NUC7i3BNH. TV Samsung QE55Q7FAMT 4K HDR. HDMI Cable 2.0 (Xbox one S).
Hi, I think I have the same problem with my NUC7i3BNH (the one with SSD slot).
I have it connected to a Samsung UE55JS8005 4K HDR TV, and they've been best friends for about a year with everything working good (even 4K resolution). A couple of weeks ago they started arguing and bickering, with the result of flicker and blackouts on the screen.
You can see a short video here: https://www.dropbox.com/s/gl857avmlhqxyhe/2018-01-04%2018.43.04.mp4?dl=0 Dropbox - 2018-01-04 18.43.04.mp4
Windows 10 ver. 1709, latest Intel graphics driver (4877). Windows is a clean install in hope of fixing the problem. Didn't work.
Yes, this is the problem.
JuanRuiz: Thank you very much for contacting the Intel® NUC communities. We are sorry to hear the NUC is not working properly.
In regard to this matter, there is another driver version that we can test in order to try to fix this problem, it is version 4901:
https://downloadcenter.intel.com/download/27412/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?pr... https://downloadcenter.intel.com/download/27412/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?pr...
Any further questions, please let me know.
Alberto R
JuanRuiz: Thank you very much for providing those details.
Could you please explain what do you mean with "HDR still does not work? Please provide a detailed description.
newman221: Please submit your inquiry on a new thread, the reason for this is that every scenario is different even if the same product is being used, so for us to better assist you and in order to try to fix the problem, please submit a new thread:
/community/tech https://communities.intel.com/community/tech
Let me apologize for any inconvenience.
Alberto R
Video demo (driver 4877 and 4901), bios 0061:
https://1drv.ms/v/s!AkeopNy9Dr-1grhvZ5F0IRfQziV8Iw https://1drv.ms/v/s!AkeopNy9Dr-1grhvZ5F0IRfQziV8Iw
JuanRuiz: Thank you very much for providing that information and the video. We will do further research on this subject, as soon as I get any updates I will post all the details on this thread.
Alberto R
Can I downgrade to bios version 0057?
Same problem, flashing screen, Samsung tv
intel_corp Can I downgrade to bios version 0057?
Using the BIOS Recovery process, you can downgrade to any previous version of the BIOS that did not introduce a security enhancement or implement an architectural change in the overall firmware (BIOS releases (also) contain lots of firmware other than the BIOS). Once you get to such a release, it is a barrier and you cannot downgrade to any previous BIOS version.
In the case of BN, the last BIOS that included/introduced one of these fixes/changes was BIOS 49. Bottom line, from BIOS 61, you can downgrade to any BIOS in the range 50-60.
You might ask how I know this. It is explained in the BIOS Release Notes. In the information provided for BIOS release 50, the following comment is included: "Due to a security enhancement, it will not be possible to go to any BIOS earlier than BIOS 0050".
Does that explain it?
Let me add an additional comment...
When you downgrade a BIOS, it is possible that the current BIOS Configuration settings will not exactly match those supported by this previous BIOS. As a result, the settings may not be what you think they are or want them to be. I recommend that, after performing a BIOS downgrade, you use the following process to ensure that the BIOS Configuration is correct:
Hope this helps,
I've made a new thread for you.
I have downgrade to BIOS 0057 and flashes disapear. But HDR still doesn't work, in all driver versions (4877, 4901, ...)
Hi JuanRuiz:
Based on the screenshot you posted before, I see the the graphics driver has HDR enabled (Windows graphics configuration top side of the image). on the lower side I see what you report about HDR not being able to activate, is that an application? See below, I circled it in blue color:
Ronny G
Below is the image of a samsung television. He's not picking up a video signal on HDR.
