Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC7i3BNH second SATA port?
Jump to solution
I recently bought a NUC7i3BNH. In the tech specs it says it has 2 internal SATA connections, but the board has only one connector. How can I connect a second SATA drive?
Thanks in advance,
DuKH.
Accepted Solutions
Highlighted
Super User Retired Employee
The second SATA lane is routed to the M.2 connector primarily to support M.2 SATA SSDs. It is possible, however, to get a M.2 card that exposes the SATA lane as a SATA connector. There is no internal source for powering the connected drive and there is no room to house this second drive within the chassis (in fact, the chassis may not even be able to close with this M.2 card installed).
Highlighted
Highlighted
Thanks for your reply, that's exactly what I was looking for.
Can you point me to where I can get such a M.2 card (that exposes the SATA connector)?
[ EDIT: I found this item https://www.amazon.com/SATA-NGFF-Socket-Adapter-Converter/dp/B00XQ9MZIW SATA HDD to M.2 NGFF Socket Adapter Converter Card: Computers & Accessories is this it? ]
Thanks again,
Pedro.
Highlighted
Yes, though there are others. Check the MicroSATACables site for a selection.
