Hi
No issue with DTS_MA (96/24) and with other encoded HD format but sound in case of PCM from and above 88.2/24 is broken more and more as quality is higher and higher.
It is same problem with Direct Sound and WASAPI, with foobar2k and Jriver and Kodi.
I tried latest three Intel Audio Drivers but problem is same.
win64_154518.4664.exe
GFX_WIN10_64_15.46.5.4771_BN.zip
GFX_WIN10_64_win64_154702.4815.zip
DAC is Pioneer Receiver SC-LX 59 which is working fine from other sources via HDMI too.
OS: Win10pro 1703
Update: I have tried over all HDMI port on the receiver. Surprisingly only 4K HDCP2.2 port were effected. I would emphasize that other sources can drive these ports too without issue.
Hello obladi,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with the sound on an Intel® NUC Kit NUC7i3BNK.
To better assist you with your request, I will need to check some more information. Please let me know what is the name of the software that you are using to test the audio and to confirm that the audio is broken from and above 88.2/16, and let me know how is the issue happening so we can try to replicate it in our labs. Also, if possible upload a file with this issue to a file sharing service so I can download it and use in my lab test.
Xavier A.
Thanks for your reply. Please find example and setting detail and my answer in following link.
https://drive.google.com/drive/folders/0B1xSPgrnJNWWd3dHYjkzaWpYZTA?usp=sharing https://drive.google.com/drive/folders/0B1xSPgrnJNWWd3dHYjkzaWpYZTA?usp=sharing
Hello obladi,
Thank you very much for the information. We will perform a laboratory test to try to replicate the issue so we can look for a solution for you.
This may take some time, so I will be contacting you back in a week or less to inform you about our results.
Xavier A.
Hello obladi,
Thank you for your patience. We were unable to replicate the issue with the latest driver version, which was recently released on November 7.
I would recommend you to manually clean install the latest driver and test again to see if the issue was fixed with the update. First, you will need to uninstall and delete the driver in your system, and then you can proceed to manually install the latest driver,
Please follow the steps below to uninstall the graphics driver:
- On the keyboard, press WinLogo key + R, then type in devmgmt.msc
- Expand the Display Adapters section.
- Find the Intel® Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
- Right-click the Intel Graphics Driver and select Uninstall.
- Select the check box Delete the driver software for this device.
- Reboot the computer after the uninstall process has finished.
- Download the graphics driver ZIP file: https://downloadmirror.intel.com/27266/a08/win64_15600.4849.zip
- Unzip the file to a designated location or folder.
- Right-click Windows Start icon and open Device Manager.
- Click Yes when prompted for permission from User Account Control.
- Expand the Display adapters section.
- Right-click the Intel® graphics entry and select Update Driver Software.
- Click "Browse my computer for driver software".
- Click "Let me pick from a list of device drivers on my computer".
- Click "Have Disk".
- Click "Browse".
- Access the designated location or folder, and access a folder called "Graphics".
- Select the file called "igdlh64" or "igdlh".
- Click Open, then click OK, and finally click Next. Drivers are now being installed.
- Reboot your computer.
https://communities.intel.com/thread/77761 https://communities.intel.com/thread/77761
Xavier A.
Thanks for your reply Xavier. I did the following updates.
1) I bought a new HDMI cable marked 2.0 on cover. Although my other cables should be 2.0.
2) BIOS was updated from 52 to 54. It didn't helped.
3) HDMI firmware was updated from 1.66 to 1.72. It did't helped.
4 I followed your guide is in previous post step by step. It didn't helped.
So the root-cause can be due to
1. Intel audio driver (HDMI2.0 compatibility)
2. Intel HDMI hardware or firmware (I am afraid that the device itself is wrong but proving it to dealer will be a bit difficult.)
3. Pioneer receiver HDMI input. (Unfortunately I have only the NUC as HDMI 2.0 source but driving amplifier from any other 1.4 compatible device it sounds good.)
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
PCM sound from and above 88.2/24 is broken more and more as quality is higher and higher.
Problem exists with Direct Sound and WASAPI too. With foobar2k or Jriver or Kodi or any other player.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
X Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
NUC7i3BNK
Hybrid or switchable graphics system?
Hello obladi,
Thank you for the information. We will be escalating the issue to the next level of support to be able to look for a solution for you.
Please have in mind that it may take some time to get a result, but we will post back to keep you updated.
Xavier A.
Hello obladi,
The Intel® NUC Board NUC7i3BNB supports for the following formats:
When you have your NUC connected to Pioneer Receiver SC-LX 59 and you play anything on 2 channels at 176.4Khz is when you get the audio broken? How broken?
Is it possible that you test the same but connected to the TV or to any other speaker set? I just want to rule out the receiver.
Ronny G
Hi Ronny,
Thanks for your answer. You can find examples how it sounds, what I mean by broken sound. Sorry if I use wrong expression.
https://drive.google.com/drive/folders/0B1xSPgrnJNWWd3dHYjkzaWpYZTA%3Fusp%3Dsharing https://drive.google.com/drive/folders/0B1xSPgrnJNWWd3dHYjkzaWpYZTA?usp=sharing
Breafly. This Pioneer receiver has several HDMI input channel but only 3 are HDMI 2.0 (and HDCP 2.2) compatible. I experience broken sound if I connect NUC to any of these 3 HDMI 2.0 port. If I connect to any other 1.4 compatible port, sound is perfect.
Unfortunately currently I have only these two HDMI 2.0 capable devices ergo I cannot try NUC with other HDMI 2.0 device. Also my TV set is HDMI 1.4 or 1.3 compatible. I know that in this way I cannot decide which device (NUC or Pioneer) has problem but any other 1.4 device I have (PCs, laptops) sound perfectly connecting to any port of Pioneer even with 192/24 stream.
BTW something is very strange. You copied part of specification here and max LPCM resolution defined as 176/24. Well when I bought this piece the following was written documentation.
It makes me think. If 176/24 is written there in that time I am not sure I would have bought it at all. May be. Anyway.
I hope you find the root-cause.
Obladi
Hello obladi,
We are currently investigating this issue and we will get back to you soon.
Ronny G
Meanwile I tried a laptop with CPU 8250U.
Acer Swift 3 SF315-51-59Y3Video card is same 620. I don't know whether it is good news or bad news but it sounded perfecty in any way In any hdmi input of Pioneer receiver. Also the fresh spec of Acer does not contains 192/24 mode either. So something is not OK around 620. Or?
Hello obladi,
I have been investigating this issue and also trying to duplicate with no success.
I have an equivalent system but connected to a different Brand/Model AVR and I am having no audio issues when playing the audio files you provided us with.
At this point and based on the fact that this issue has been pending for quite some time already, I would recommend that you run latest Graphics drivers (4901): https://downloadcenter.intel.com/download/26947/NUCs-Intel-HD-Graphics-Driver-for-Windows-10-for-Intel-NUC-Kit-NUC7i3BN-NUC7i5BN-and-NUC7i7BN?product=95069 Download Intel® HD Graphics Driver for Windows® 10* for Intel® NUC Kit NUC7i3BN, NUC7i5BN, and NUC7i7BN if the issue still persist please get in contact with our technical support service via phone: https://www.intel.com/content/www/us/en/support/contact-support.html# @6 Contact Support and please make reference to case: 3069255.
Ronny G
I think that this is point where I have to give up. I have already used Nvidia or ATI for many years but I though that Intel have learned to manufacture video card. I need video option rather than game therefore it looked a good choice. I am very disappointed. Not just because of this issue. It is just the most bothering one. I am also facing to other issues too which are mentioned here in the forum. I know that that many of these will be solved (or not) by a future driver update and not Intel is responsible for all. Still.
Believe me I tried everything is possible from a user. I continuously check driver update as well MS updates and what is more a Pioneer firmware update has been released meanwhile. Nothing has helped. My opinion is that there is good chance for a unique error of my equipment. I would take (or send) it to the service but I am afraid it will be an endless process.
I mentioned the laptop with CPU 8250U and also I said that it sounds perfectly but I didn't mentioned that video was failed. I have got only blank black screen. It can be due to many reason but video card is same HD Grapics 620. I tried laptop a few monitors too and video output was perfect in every cases. I don't list the possible rootcauses. The point is that the two HD Grapics 620 cards behaves differently. Thanks for your help but I am sick of it. It would be best if I try to sell it and look for other manufacturer. I regret for my choice.
Hello obladi,
I am really sorry to hear that you have been dealing with multiple issues with this NUC, I would really like to offer you a quick resolution but resolving issues of this nature, specially when it may involve 3rd party devices may take a long time.
I would recommend that you contact us by Phone or Chat, here is the "contact us" information: https://www.intel.com/content/www/us/en/support/contact-support.html https://www.intel.com/content/www/us/en/support/contact-support.html and make reference to case: 3069255 to explore other possible solutions.
Ronny G
Hi Ronny, All,
I installed latest Graphic card driver GFX_Win10_64_24.20.100.6194_BN and see the miracle! It works! May be this is not the first release which works fine. I got tired of testing it every time I install new one sorry but usually I did.
One more thing, the max LPCM output resolution is 192/24 again. :-) Well it is nice job finally. It was only matter of time isn't it.
Thank you
Best regards
