Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC7i3BNK M.2 logical device interfaces and command sets supports list
Hello!
Somebody can prompt, NUC7i3BNK's M.2 does supports Legasy SATA and PCI Express using NVMe logical device interfaces and command sets simultaneous?
In specification indicate that, it's have
Total # of SATA Ports 2
Max # of SATA 6.0 Gb/s Ports 2
If to assume that one of SATA sockets, is additional and the second M.2, it means supports?
Quite good it would be obvious to specify in the specification - Support of the protocol M.2: Legasy SATA/PCI Express using AHCI/PCI Express using NVMe
Tags (1)
Highlighted
Community Manager
Hello Zhavokhir,
I understand you would like to know if the Intel® NUC Kit NUC7i3BNK supports Legacy SATA and PCI Express using NVMe logical device interfaces and command sets simultaneously.
Let me apologize for any inconvenience this issue may be causing to you.
Let me do some research about this and come back to you.
I will post information on this forum thread as soon as I have it available.
Fred D.
Highlighted
Super User Retired Employee
Actually, I can answer this. If you plug in a SATA drive, the PCIe interface is disabled. The vice versa case also occurs. Bottom line, both interfaces cannot be used simultaneously.
