Community
cancel
Showing results for
Search instead for
Did you mean:
GGac
NUC7i3DNH how to disable Setup and BootList buttons on startup screen
In NUC7i3DNH on startup screen in right upper corner there are two buttons "Setup" and "BootList", when i tap touchscreen on it i can enter to BIOS or open boot device list.
How to disable those buttons?
LeonWaksman
Enter Bios Setup during boot (press F2)
Enter Advanced ->Boot
Remove Checkbox in the following fields:
-Display F2 to Enter Setup
- Display F10 to Enter Boot Menu
Press F10 followed by "Y" to save new settings and exit
F2 and F10 key input will still be accepted if this prompt is disabled.
Leon
GGac
If it is so easy, I would not ask in this forum.
I would like not switching off the text on the right side of the screen at the bottom, just the buttons on the top right.
