Community
cancel
Showing results for
Search instead for
Did you mean:
APesc1
NUC7i5BNH LiveKernelEvent error 144
I received the here-under error message; but, after it, NUC & screen (Samsung smart TV 4K) are running normally
Origine
Windows
Riepilogo
Errore hardware
Data
‎18.‎03.‎18 10:18
Stato
Segnalazione non inviata
Descrizione
Si è verificato un problema dell'hardware che impedisce il corretto funzionamento di Windows.
Firma del problema
Nome evento problema: LiveKernelEvent
Codice: 144
Parametro 1: 3003
Parametro 2: ffff94086b777708
Parametro 3: 40010000
Parametro 4: 0
Versione sistema operativo: 10_0_16299
Service Pack: 0_0
Prodotto: 256_1
Versione SO: 10.0.16299.2.0.0.256.48
ID impostazioni locali: 1040
May I take any action?
Tags (1)
Community Manager
Hello AugustoP,
I understand that you received an error message regarding hardware but your system is working fine.
Regarding this, it is hard to detect which hardware is currently giving errors with that information so To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
After I get this I will go ahead and check any possible out-dated drivers or any anomaly.
David V
APesc1
Hello David, thank for your help.
Attached the requested report.
B. regards
Augusto
Community Manager
Hello AugustoP,
Thank you for your response,
I can see that everything is up to date and there doesn't seem to be any anomaly among the different hardware parts.
Up to this point, if the error were to happen again, I will greatly appreciate if you could take a screenshot and attach it to the thread.
David V
APesc1
I'll follow your suggestions.
Best regards
Augusto
