Community
cancel
Showing results for
Search instead for
Did you mean:
LDebb
NUC7i5BNH Screen goes Black with LG 4K monitor
Just got me a new NUC,
And the screen keep going black when there is movement,
What I did so far:
1. Bios update
2. Display driver Update
3. Tried to update the HDMI driver ( was the last one)
The only workaround that works is to lower the refresh rate to 30hz at the display driver, but I cant work like that
Please help and advice
n_scott_pearson
Super User Retired Employee
Get a better quality HDMI 2.0a/b cable.
n_scott_pearson
Oh, and make sure you are using the HDMI port that provides support for 4K@60Hz. It may not be HDMI1 (some other folks have run into this).
LDebb
I will give it a try,
Meanwhile its connected to a 1080P Samsung and no problems
GSher1
Is there a _BN in the graphics driver name. Example: 15.65.4.4944_BN. This was a problem for a long time when these NUC's were new.
n_scott_pearson
Yes, there is. For the BN NUCs, do not use versions of the Intel HD Graphics Driver package that do not have the "_BN" in the file name.
