Did you try with nothing attached to the TB port. I installed tbt_win10_64_17.2.71.250 again and then FW33, it did the registry update and after reboot it successfuly installed.
I'm trying to install the TBT FW 33, the first install steps performed normally but the flashing process failed with the error 0x103 POWER_CYCLE_FAILED_CODE
The .reg is applied and the computer rebooted.
The TBT driver installed is tbt_win10_64_17.2.71.250
My config details extrated with Intel SU is in attachement.
My screen was connected in DisplayPort through the Thunderbolt port so I switched to HDMI
Tried to flash: Failed
Reboot (in HDMI)
Tried to flash: Success
It's strange that I have to disconnect any Thunderbolt peripherical because the flashtool said "Please connect at least one Thunderbolt device to your PC"...
Anyway thanks for your support
