I have a NUC7i5BNH which i planned to have as a server running Linux. However, if i don't use the NUC for a while it hybernates.
Any idea how i can prevent this?
[ 1347.989436] ------------[ cut here ]------------
[ 1347.989478] NETDEV WATCHDOG: eth0 (e1000e): transmit queue 0 timed out
[ 1347.989555] WARNING: CPU: 3 PID: 0 at net/sched/sch_generic.c:443 dev_watchdog+0x253/0x260
[ 1347.989559] Modules linked in: ctr ccm fuse intel_rapl binfmt_misc nls_ascii nls_cp437 vfat fat arc4 snd_soc_skl snd_hda_codec_hdmi snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi btusb btrtl snd_hda_codec_realtek btbcm snd_soc_core btintel x86_pkg_temp_thermal iwlmvm snd_hda_codec_generic intel_powerclamp ledtrig_audio coretemp bluetooth snd_compress mac80211 kvm_intel snd_hda_intel kvm snd_hda_codec drbg iwlwifi irqbypass rtsx_pci_ms snd_hda_core intel_cstate ansi_cprng snd_hwdep intel_uncore memstick ecdh_generic intel_rapl_perf snd_pcm ecc sg iTCO_wdt efi_pstore cfg80211 iTCO_vendor_support mei_me snd_timer ir_rc6_decoder rfkill intel_wmi_thunderbolt watchdog mei snd soundcore wmi_bmof intel_pch_thermal pcc_cpufreq efivars pcspkr rc_rc6_mce ite_cir rc_core tpm_crb tpm_tis tpm_tis_core evdev tpm rng_core acpi_pad efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic sd_mod crct10dif_pclmul crc32_pclmul
[ 1347.989707] crc32c_intel ghash_clmulni_intel rtsx_pci_sdmmc mmc_core aesni_intel i915 aes_x86_64 crypto_simd cryptd glue_helper ahci xhci_pci i2c_algo_bit libahci xhci_hcd drm_kms_helper e1000e libata ptp i2c_i801 pps_core scsi_mod rtsx_pci mfd_core usbcore drm usb_common wmi video button
[ 1347.989764] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.2.0-kali2-amd64 #1 Debian 5.2.9-2kali1
[ 1347.989768] Hardware name: Intel Corporation NUC7i5BNH/NUC7i5BNB, BIOS BNKBL357.86A.0063.2018.0413.1542 04/13/2018
[ 1347.989783] RIP: 0010:dev_watchdog+0x253/0x260
[ 1347.989793] Code: 48 85 c0 75 e4 eb 9d 4c 89 ef c6 05 33 b6 aa 00 01 e8 f1 3f fb ff 89 d9 4c 89 ee 48 c7 c7 88 32 50 84 48 89 c2 e8 97 da a2 ff <0f> 0b e9 7c ff ff ff 66 0f 1f 44 00 00 0f 1f 44 00 00 41 57 41 56
[ 1347.989799] RSP: 0018:ffffab3900da4e88 EFLAGS: 00010282
[ 1347.989806] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000083f
[ 1347.989810] RDX: 0000000000000000 RSI: 00000000000000f6 RDI: 000000000000083f
[ 1347.989814] RBP: ffff981f66b2045c R08: 0000000000000369 R09: 0000000000000004
[ 1347.989819] R10: 0000000000000000 R11: 0000000000000001 R12: ffff981f664e4280
[ 1347.989824] R13: ffff981f66b20000 R14: ffff981f66b20480 R15: 0000000000000001
[ 1347.989832] FS: 0000000000000000(0000) GS:ffff981f76b80000(0000) knlGS:0000000000000000
[ 1347.989837] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1347.989842] CR2: 0000279900748fe0 CR3: 000000007100a004 CR4: 00000000003606e0
[ 1347.989847] Call Trace:
[ 1347.989854] <IRQ>
[ 1347.989872] ? pfifo_fast_enqueue+0x130/0x130
[ 1347.989883] call_timer_fn+0x2d/0x130
[ 1347.989893] run_timer_softirq+0x401/0x440
[ 1347.989904] ? __hrtimer_run_queues+0x110/0x280
[ 1347.989915] ? recalibrate_cpu_khz+0x10/0x10
[ 1347.989926] ? ktime_get+0x3a/0xa0
[ 1347.989938] __do_softirq+0xde/0x2f7
[ 1347.989955] irq_exit+0xab/0xb0
[ 1347.989966] smp_apic_timer_interrupt+0x74/0x140
[ 1347.989976] apic_timer_interrupt+0xf/0x20
[ 1347.989981] </IRQ>
[ 1347.989994] RIP: 0010:cpuidle_enter_state+0xbc/0x450
[ 1347.990002] Code: e8 19 45 af ff 80 7c 24 13 00 74 17 9c 58 0f 1f 44 00 00 f6 c4 02 0f 85 67 03 00 00 31 ff e8 2b 63 b5 ff fb 66 0f 1f 44 00 00 <45> 85 e4 0f 89 d1 01 00 00 c7 45 10 00 00 00 00 48 83 c4 18 44 89
[ 1347.990009] RSP: 0018:ffffab3900d1be78 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff13
[ 1347.990016] RAX: ffff981f76baa0c0 RBX: ffffffff846b7c60 RCX: 000000000000001f
[ 1347.990020] RDX: 00000139da6dddfc RSI: 0000000039f89468 RDI: 0000000000000000
[ 1347.990024] RBP: ffffcb38ffd82010 R08: 0000000000000002 R09: 0000000000029940
[ 1347.990028] R10: 00000048ce783584 R11: ffff981f76ba9064 R12: 0000000000000006
[ 1347.990032] R13: ffffffff846b7eb8 R14: 0000000000000006 R15: 0000000000000000
[ 1347.990049] ? cpuidle_enter_state+0x97/0x450
[ 1347.990060] cpuidle_enter+0x29/0x40
[ 1347.990072] do_idle+0x236/0x280
[ 1347.990084] cpu_startup_entry+0x19/0x20
[ 1347.990094] start_secondary+0x17a/0x1d0
[ 1347.990105] secondary_startup_64+0xa4/0xb0
[ 1347.990116] ---[ end trace 504310c3bf966330 ]---
You know that only windows 10 is supported on your NUC, right?
https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html
Contact the linux community for assistance.
Doc
Yes, i know that only Windows 10 is supported. Thanks for all the help resolving my issue with the Intel NUC.
