Intel® NUCs
12102 Discussions
NUC7i5BNH fan noise profile
GDiak
I got a NUC7i5BNH a couple of months ago, replacing my four year old NUC5i3RYH. One of the points I like about the NUCs is the noise levels, since I want my pcs to be really quiet. What I did with both NUCs is setting up the fan minimum duty cycle to 25-31% (with relevant changes to the other fields to make sure they don't overheat), which makes for a barely audible pc running at acceptable temperatures.
It seems the situation was the same for the new 7i5 model at first, but I noticed that soon the noise profile changed. While still not really loud, it gives a high pitched sound which is annoying and more audible. I'm almost certain this changed gradually, first after running intensive tasks requiring higher rpm, and afterwards all of the time, regardless of rpm.
I attach two short recordings, taken at 10cm from the NUC, one at the default 45% duty cycle and another at 25%, mostly to illustrate the noise profile.
Is this type of fan noise normal? If no, could it be due to a faulty fan?
n_scott_pearson
Super User Retired Employee
It's technically a blower, not a fan.
What this first recording sounds like - this ticking - is likely the blades of the blower touching (rubbing) the blower's cowling. You can sometimes remedy this by tugging up on the cowling all the way around the inlet (opening) into the blower. I used a dental pick to do this the time that I had to do so (in this case, I actually caused the problem by leaning on the blower; this was while testing a bare board (no chassis)).
The second recording sounds similar, but was recorded when the blower was spinning at a faster speed (i.e higher duty cycle). That extra high-pitch "ring" could be the result of the rubbing or it could be the result of a loose bearing.
I suggest that you try my remedy. If this doesn't fix it, you can look for a replacement blower. If you cannot find one (which shouldn't be the case; it is a standard part; just use the part number on the side of it), you can always consider having Intel replace the unit under warranty...
Hope this helps,
GDiak
Thanks for your reply, it's good to have such a specific explanation. I was suspecting it was a mechanical issue, but I couldn't be 100% certain due to this being a new machine and different from my old NUC. I'll try your suggestion and I'll report back.
Edit: On second thought I think I'll look for a replacement fan, perhaps if I can get Intel to send one. I can easily replace a fan, but messing with mechanical parts might be risky, not to mention that it should void the warranty and that the said blower is probably defective anyway.
Alberto_R_Intel
GDiak, Thank you for posting in the Intel® Communities Support. As additional information, the Intel® warranty option for this scenario and for this specific model is to replace the whole unit, the fan itself is not available as a spare part in the Intel® inventory for us to replace it when using the Intel® NUC Kit NUC7i5BNH. We have reports that some users were able to replace the fan, but in that case that is done based on 3rd party information at their own risk, as you mentioned previously, to try to replace just the fan will avoid the Intel® warranty. In the case you are interested in replacing the NUC, please get in contact directly either with the place of purchase, to confirm if they might have that option available, or you can always contact your local Intel® support department for further assistance on this matter: Chat support: http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat, For phone support, depending on your location, you will see the contact information on the links below: EMEA contact information: https://www.intel.com/content/www/us/en/support/contact-support/emea-contact.html APAC contact information: https://www.intel.com/content/www/us/en/support/contact-support/apac-contact.html LAR contact information: https://www.intel.la/content/www/xl/es/support/contact-support/lar-contact.html North America: Phone Number 1-916-377-7000 Monday – Friday 7:00 AM to 5:00 PM (Pacific Time). Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
GDiak
Update: Rather than going through the warranty process, which would leave me without my main computer for 2 weeks at best, I order a replacement blower. This NUC comes with an AVC BAAA0508R5H 5V/0.5A blower; I received a very similar blower (I think it's AVC BAPA0508R5H) which was obviously of superior quality, as most of its parts are metallic in contrast to the plastic design of the original blower. And, other than fixing the noise issue, the replacement fan did a huge difference concerning cpu temperatures, which dropped by some 5-10 degrees. For instance, a 25% cycle duty keeps the cpu temperature in the low 40s under casual usage, and there's never any need for more than 25% unless the GPU kicks in.
Point is, it was a bit disappointing to see that Intel cut productions costs by choosing an inferior blower when there were better options. I hope they changed this in the 8th generation NUCs.
Alberto_R_Intel
GDiak, Thank you very much for letting us now those results, we are glad to hear that you were able to replace the fan. We also appreciate your feedback, and I will send your suggestions to the proper department for them to be aware of your comments. Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
