Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC7i5BNK / NUC7i3BNK graphic card issues with Ubuntu 14.04
Jump to solution
I am currently testing 7th generation i3/i5 NUCS (NUC7i5BNK and NUC7i3BNK) with a custom operating system based on Ubuntu 14.04. I am experiencing issues with the graphic card (really slow performance during long periods of time), specially when playing HTML5/Flash videos from firefox. When this happens, Xorg process CPU usage reaches 100% (as seen in top command). This issue doesn't happen with Ubuntu 16.04.
Are you aware of similar graphic card issues with Ubuntu 14.04? Is there any driver update to fix this?
Tags (1)
Accepted Solutions
Highlighted
Community Manager
Hello Beabloo,
Thank you for contacting the Intel community.
I'm sorry about the issue you have experience with the Intel® NUC and Ubuntu.
Please bear in mind that Intel hasn't validated these operating systems. We recommend you use the latest kernel. If you need assistance with Linux* on Intel NUC, check your distro's website and forums for peer assistance.
https://www.ubuntu.com/ https://www.ubuntu.com/
Please see the https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-nuc-boards/000005628.html Supported Operating Systems for Intel® NUC Products
Ivan U.
Highlighted
Community Manager
Hello Beabloo,
Ivan U.
