Hi, I have the same problem as reported by many in the previous threads on the subject although it's not so much a flash, but more of a flicker. Parts of the screen are fine while others kinda look "corrupt", maybe go green or pink for just a few milliseconds. I'm on 4K and screen flickers in many of the times when there are big "changes" in whatever's displayed. Fast scrolling through text, opening the Start menu, switching tabs in the browser and setting Youtube to full screen - these are just some of the times when the problem is prominent.
I have had this NUC for 9 months and this has never happened before. It only started this week, and I've made no recent changes to the system, nor installed anything.
I updated my BIOS and graphics driver to the latest versions, but to no avail. The problem persists. I even tried a different HDMI cable.
I've attached my Intel System Support Utility summary. Hopefully someone here can help.
Asaf.
What has likely happened is Windows Update has installed a newer version of the Intel HD Graphics driver package - one that is causing problems with your monitor/TV.
I hope this helps,
I hope this helps,
I do run the latest BIOS, and I did download the latest graphics driver. However, it wasn't from the link you provided. Now after I did use your link, I think the flickering stopped. I'll update here if the problem reoccurs.
Amazing, thanks so much, N. Scott!
Unfortunately, I am having a similar problem with the most updated BIOS and graphics drivers. Is there anything else you can suggest? My problem is just that the screen goes to black for a second or two. This happens frequently, but it is the only graphics issue. No part of the screen is corrupt or appears in the wrong color; the whole screen just goes to black and then recovers quickly.
I've attached my own "detailed system report."
Thank you,
SB
Hello sb242349,
Thank you for joining this Intel Community.
I understand that your display experiences flickering issues frequently. I would like to assist you.
I would like to know if this screen flickering occurs when you open a specific application or watch high quality videos in YouTube*. This will help us address your issue better.
In addition, you can try installing the latest graphics driver for your unit's graphics controller Intel® Iris® Plus Graphics 650, which fixes graphics anomalies and adds WebGL* improvements in the Chrome* web browser.
https://downloadcenter.intel.com/download/27892/Intel-Graphics-Driver-for-Windows-10
Wanner G.
Hello sb242349,
Were you able to install the latest graphics driver for your graphics controller?
We will be glad to continue assisting you If screen flickering still occurs.
Wanner G.
Hi Support
I have 15 of the NUC7i5BNK units on a company network. 6 of them have started having intermittant screen flashing issues on both the HDMI port and the USB-c Port.
Both screens attached are 1080@60Hz.
I have tried Installing the latest BIOS Updates and the latest Graphics card firmware i can find.
Please can you confirm the best drivers to be using?
The screen just turns off for around a second and then come back on again randomly.
We have tried replacing screens and HDMI / USB C Cables.
Many thanks
