Hi people,
So i try to setup an UHD lcd panel to work on my NUC, but i want to use it as a main screen (no hdmi).
The problem is i can't get it to work alone, it only comes-up when there is an HDMI screen connected.
I can see the backlight turning on on boot, but no picture. The HDMI screen though always works.
Since as i found out, the lcd panel defaults on the nuc's bios need adjustment for the lcd to work ok, (i.e. the inverter pwm frequency default is too low, and my lcd needs a higher setting).
BTW when it works, it's just brilliant.
i wonder if any one has a bios settings recipe for this (work ONLY with the eDP panel)
Hello Asxetos21,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
2. Provide the Report for Intel® Graphics Drivers:
3. What is the brand and model name of your monitor?
4. Was the monitor working with another computer or laptop?
5. Have you tried with other DP cables?
Deivid A.
Hello Asxetos21,
After checking your case, I would like to know if you need further assistance.
If so, please provide me with the information requested.
Deivid A.
Hello Asxetos21,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
