Community
cancel
Showing results for
Search instead for
Did you mean:
Agustav
NUC7i7BNH + Windows 10 = vulnerable for BlueBorne Bluetooth attack
I have the latest bluetooth driver installed (20.40.0.3) as well as the latest BIOS (0062)
but it seems to be still vulnerable by BlueBorne attack.
On my android phone i have installed "BlueBorne Scanner by Armis"
(Link: https://play.google.com/store/apps/details?id=com.armis.blueborne_detector&hl=de BlueBorne Vulnerability Scanner by Armis – Apps bei Google Play)
and it shows me "Medium Risk".
What does this mean?
Thank you.
Community Manager
Hello Agustav
Thank you for joining the community.
We are looking into your case; in the meantime please provide us with the following information:
I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Please review your private inbox.
Leonardo C.
Agustav
Community Manager
Hello Agustav
Thank you for your response.
Allow me to investigate the matter. I will be posting back as soon as news become available.
Leonardo C.
Community Manager
Hello Agustav
Thank you for waiting.
Looking for more details on the situation I have found the following link: https://www.armis.com/blueborne/ https://www.armis.com/blueborne/. Windows 10 systems are affected by security variance (CVE-2017-8628).
Please refer to https://portal.msrc.microsoft.com/en-US/security-guidance/advisory/CVE-2017-8628 https://portal.msrc.microsoft.com/en-US/security-guidance/advisory/CVE-2017-8628; you need to install the latest Windows Update, you should be able to install one of the following: 4038783, 4038782, 4038788 (only 1 is needed depending on the Windows 10 build that you are using).
If you need assistance with the selection of the correct update we recommend to contact Microsoft for assistance.
Hope this helps.
Leonardo C.
Agustav
thank you for the links, but KB4038783, KB4038782 and KB4038788 are for Windows 10 Build 1511, 1603 and 1607.
But i have installed Build 1609 (KB4054517) so i am unable to install one of those updates
Today i installed the latest Windows updates, but the vulnerabilty scanner by Armis is still showing me "medium risk".
Community Manager
Hello Agustav
As mentioned in the previous post to find the correct update for your version of Windows we recommend to contacting Microsoft for guidance on the matter.
Leonardo C.
