Community
cancel
Showing results for
Search instead for
Did you mean:
mpell6
NUC7i7BNH & 4K - Did I mess up?
Jump to solution
Recently acquired a NUC7i7BNH to fill-in as a light duty Plex server (single stream, mostly direct play).
Win10 Pro
500GB m.2 SSD
2TB HDD
Cat 5 Wired
All seems to be working except when I attempt to use the NUC as a Plex client. I get playback on my 1080p content, but a only black screen (w/audio) for 4K HDR content. The NUC can serve 4K content to my other Plex clients with no complaints (AndroidTV, LGTV, TiVo). Using the NUC as a Plex client/player is my issue. Before purchasing, I had read 4K playback was possible on these devices.
So far, here are my steps:
1. Swapped out HDMI cables, swapped to alternate HDMI Inputs to LGTV 4K TV
2. Updated BIOS to latest v1.72, dated 11/20/2017 (claims to update HDMI 2.0 Firmware)
3. Updated Graphics driver to latest v24.20.100.6025, dated 5/7/2018
Multiple reboots, confirmed the BIOS and drivers updates have "stuck", still getting blank screen with 4K content.
Questions:
1. Did I misunderstand the 4K playback capability of this device?
2. Any other BIOS/Config settings to tweak?
3. Any suggestions to get this NUC working as expected?
Thank you!
Mark
Tags (1)
mpell6
Following up:
It appears as if Intel NUC7i7 & Win10 are not the culprit here.
1. Win10 Settings > Display > Select HDR/WCG = ON - LGTV flips to HDR mode and displays the expected indicator on-screen
Even in Win10's HDR mode (noted above), Plex will not play HDR content, just HD/SDR. HDR content appears as Back Screen w/audio.
So, a Plex Media Player issue.
mHoug
if i'm reading your thread right then your using plex as the player, does that support 4k HDR playback? if not then no go. the hardware is capable but still needs the software
mpell6
Following up:
