Community
cancel
Showing results for
Search instead for
Did you mean:
CFabe
NUC7i7BNH loses video after samsung HDMI 2.0 TV is shutoff / turned on again
So the title says this pretty well. I had exactly the same problem before I shifted from Linux to Windows 10 for an HTPC. As soon as the TV shuts off the Intel NUC loses connection (via HDMI) to the TV and when the TV comes back online it stays blank until the HDMI cable is physically unplugged / plugged back in.
It's running the latest drivers pack from Intel but I don't think that's the issue, as both linux and now windows exhibit the same problem. I've tried two NUC7i7BNH's, both of which experienced this identical problem so I suspect it's very likely protocol handling problems between two HDMI 2.0 devices.
It's possible that there's something up with the TV however none of the other HDMI devices connected to it are experiencing this problem.
Does anyone have any suggestions on what to try here?
Tags (1)
jema
Do you have a receiver to try with as a go between device? If not and the tv has multiple hdmi ports try using a different port.
And check out the updates. There is a hdmi related update but what it does escapes me now.
Community Manager
Hello cfaber,
Thank you for joining the Intel Community Support
Having the latest Intel® HD Graphics Driver and BIOS update installed may help you fix the issue.
For this reason, I would like to gather basic system information. Please scan your Intel NUC using the Intel® System Support Utility. Follow the steps below:
1.Download the Intel® System Support Utility and save the application to your system here:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Download Intel® System Support Utility for Windows*
2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View.
3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
4. Attach the report to this thread.
Thank you jema for your helpful suggestions. In fact, I will be providing additional information about the HDMI 2.0 firmware update after reviewing system information.
I look forward to hearing from you .
Wanner G.
CFabe
I have the latest graphics drivers installed, along with the latest bios update.
Community Manager
Hello cfaber,
Find below the latest Intel HD Graphics drivers and BIOS update you should have installed in your Intel NUC.
-Intel® HD Graphics Driver: Version: https://downloadcenter.intel.com/download/26947/Intel-HD-Graphics-Driver-for-Windows-10-for-Intel-NU... 15.60.2.4901 (Latest)
-BIOS update: Version: https://downloadcenter.intel.com/download/27571/BIOS-Update-BNKBL357-86A-?product=950650062 (Latest) 0062 (Latest)
These updates have fixed the issue where a head mounted display would not wake up from sleep. Keep in mind that you may also follow the steps below to troubleshoot your system.
-Try another HDMI cable to discard having a faulty HDMI cable
-Plug the Intel NUC into another HDMI port if available.
Additionally, you may install the https://downloadcenter.intel.com/download/26609/HDMI-2-0-Firmware-Update-Tool-for-Intel-NUC-Kit-NUC7... HDMI 2.0 Firmware Update Tool. The instructions are in the .zip file.
Wanner G.
Community Manager
Hello cfaber,
I am writing just to follow up on your inquiry. Were you able to fix the issue you were having?
I look forward to hearing from you.
Wanner G.
