Community
cancel
Showing results for
Search instead for
Did you mean:
Savarin
NUC7i7BNKQ - Overworking, overheating, shutting down (my rigged solution)
(The original post was closed)
The problem persists on a regular basis (e.g.: GoogleMaps 3D), and as soon as any ScreenSaver runs, the temperature soars. I do not have the skills to open and clean or replace the blower, like Leon suggested.
Here's my rigged solution, after removing the plastic top lid, an USB Fan blowing downwards (check HWINFO's temp specs):
AlHill
Seems a bit extreme, when just a couple of simple checks can likely solve the problem.
Doc
Savarin
and the simple checks are...
AlHill
"open and clean or replace the blower, like Leon suggested". Skills or not, there is support available to step you through these steps.
Doc
