Community
cancel
Showing results for
Search instead for
Did you mean:
rgota
NUC7i7BNKQ upgrading ram to 32gb, do I need to update anything in bios?
Jump to solution
I've just purchased a NUC7i7BNKQ - https://www.intel.com/content/www/us/en/products/boards-kits/nuc/mini-pcs/nuc7i7bnkq.html Intel® NUC 7 Enthusiast Mini PC - NUC7i7BNKQ with Windows* 10 128753
I'm doing some research on updating my ram to 32gb, that said after installing the RAM do I need to do anything in the BIOS?
Or do I just install the ram and it's good to go?
Thanks!
n_scott_pearson
Super User Retired Employee
You can access the compatibility pages for the NUC products using this link: http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC Intel® Product Compatibility Tool. In the (left-hand) Products column, click on Intel° NUC then Mini PCs then NUC7i7BNKQ and then Memory Modules. Remember that the modules listed here are just those that have been formally tested in Intel's compatibility labs; there are many others that very well could be compatible but have never been formally tested (usually because manufacturers have not provided Intel with samples).
After installing the new SODIMMs, there is really nothing that you have to do. As you say, just install them and you should be good to go. Now, when I do this, I usually run a test cycle using MemTest86+ to ensure that the memory is properly and completely exercised before I use it. This is completely optional, however.
Hope this helps,
n_scott_pearson
Hope this helps,
rgota
Thanks Scott, for the incredibly helpful response and link to the compatibility page.
Appreciate the feedback.
