Community
cancel
Showing results for
Search instead for
Did you mean:
PSpic
NUC7i7bnh cannot regocnise Kingston M2.SSD
Trying to set up a new NUC7i7BNH with a Kingston SM2280S3G2/240G M2 SSD drive.
Whatever I do, I cannot recognise it as a bootable device.
If I install a standard SSD drive I can set this as a bootable drive and install an OS (Ubuntu).
If have flashed the BIOS to 60 and defaulted.
M2 port is enabled but it shows "not populated"
Can you confirm if the device is compatible - on the Kingston site it is listed as compatible.
Thank you....
Paul.
