Community
cancel
Showing results for
Search instead for
Did you mean:
TReed
NUC7iBNH No Bluetooth devices discovered
The title pretty much says it. All drivers up to date, win10 up to date, Bluetooth devices confirmed to work on other systems.
Community Manager
Hello MolyWorks,
I understand that currently your unit is unable to discover bluetooth devices.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
TReed
Well I don't see the option to attach a file here so here is the text from the DxDiag file:
System Information
Time of this report: 4/12/2018, 16:25:58
Machine name: MICROSCOPE
Machine Id: {8CECF9CD-B5E8-4825-BC67-FCB38EEEF6CF}
Operating System: Windows 10 Pro 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
Language: English (Regional Setting: English)
System Manufacturer:
System Model:
BIOS: BNKBL357.86A.0062.2018.0222.1644
Processor: Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz (4 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16270MB RAM
Page File: 5444MB used, 13257MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.16299.0015 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Iris(R) Plus Graphics 650
Manufacturer: Intel Corporation
Chip type: Intel(R) Iris(R) Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_5927&SUBSYS_20688086&REV_06
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8263 MB
Dedicated Memory: 128 MB
Shared Memory: 8135 MB
Current Mode: 2560 x 1080 (32 bit) (59Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.651867,0.332531), Green(0.307141,0.631359), Blue(0.150891,0.060070), White Point(0.313977,0.329602)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: LG ULTRAWIDE
Monitor Id: GSM59F1
Native Mode: 2560 x 1080(p) (60.000Hz)
Output Type: HDMI
Monitor Advanced Color Capabilities: None
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\ki126934.inf_amd64_a80b5f65e02db45d\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki126934.inf_amd64_a80b5f65e02db45d\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki126934.inf_amd64_a80b5f65e02db45d\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki126934.inf_amd64_a80b5f65e02db45d\igd12umd64.dll
Driver File Version: 23.20.0016.4944 (English)
Driver Version: 23.20.16.4944
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.3
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 2/3/2018 5:00:00 PM, 1921544 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-1A67-11CF-66F0-7800BDC2DA35}
Vendor ID: 0x8086
Device ID: 0x5927
SubSys ID: 0x20688086
Revision ID: 0x0006
Driver Strong Name: oem37.inf:5f63e534fcbce094:iKBLD_w10_DS:23.20.16.4944:pci\ven_8086&dev_5927&subsys_20688086
Rank Of Driver: 00D10001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C...
Community Manager
Hello MolyWorks,
Thank you for your response,
I am currently reviewing the information, in the meantime, can you please provide me with the exact model of the unit?
For example: NUC7I3BNH,NUC7i5BNH,NUC7i7BNH.
David V
TReed
NUC7i7BNH
Community Manager
Hello MolyWorks,
We are going to the following, we are going to download the file to update the driver of the bluetooth* from the link below:
https://downloadcenter.intel.com/download/27600/Intel-Bluetooth-Technology-Based-Driver-for-Windows-... https://downloadcenter.intel.com/download/27600/Intel-Bluetooth-Technology-Based-Driver-for-Windows-...
Once the installation is complete, reboot the system and try to discover devices with the bluetooth*
David V
TReed
A slight improvement. I can see some devices, but not the one I'm looking for, which is a mprow headset. This headset shows up on my phone just fine. It was connect to the NUC and disconnected mid call and It's never been able to connect again.
FYI, that driver update gave no indication that it ran, other than a momentary blip on the screen.
Community Manager
Hello MolyWorks,
Have you checked under the bluetooth settings to see if it is still paired or not? If it is paired then I would suggest you to first forget the device under the settings and then attempt to find it again, if possible after forgetting the device, turn off the bluetooth* and then turn it back on. Then, try and re-scan to see if the unit shows.
David V
TReed
The headset is not paired at this time. While the headset was paired, there was an error when trying to reconnect. The device was forgotten and since it's never shown on the available devices screen again. The headset pairs with an android phone just fine.
Community Manager
Hello MolyWorks,
The only thing we can try now is to check if the headset is paired with any other device, if that is the case then please unpair it. After that, try to connect it to the NUC again to see if it is available now.
If that did not work, then please go to the device manager and look for the bluetooth* controller under device manager and then uninstall it. After uninstalling it, please go ahead and reboot the system. Once the system is back up, download and install the latest bluetooth* driver which was provided by me before.
Let us know the outcome.
David V
TReed
Thanks for the reply, today I ran the troubleshooter again and after running it twice the head set appeared and connected as expected. Thank you for your help.
Tom
