My NUC8I5BEK with INTEL 760P 256G SSD is connecting to Sony Tv as media center. However, once the screen off, i will never be able to wake it up by any means except to power it off and turn on again.
Here are what i did, but still cannot resolve this issue.
(1) Update all drivers and windows 10 update (1809)
(2) Disable deep sleep in BIOS
(3) 3 mins screen off
(4) never sleep
It is really annoying now as i have to set screenoff and sleep to "never"
I've been unable to resolve exactly the same issue.
Brand new NUC8i5BEK
- All drivers properly installed - and reviewed by Intel Driver and Support Assistant.
- Windows 10 Home installed.
When left alone for a while even with work open on the desktop, I will return to a Samsung monitor that is searching for a device.
The BLUE power LED is on solid.
Keyboard and mouse don't wake up the device.
The network lights show normal activity.
The fan is running at normal speed.
The only way to resolve is to hold in the power button until it switches off and then restart the NUC.
This is so frustrating it has been driving me crazy.
Event Viewer Critical errors - 41 in total since the 6-11-2018 when I first installed the new device.
The first ever event:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 2018/11/06 20:19:44
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: **************
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event">
41
6
1
63
0
0x8000400000000002
389
System
0
0x0
0x0
0x0
0x0
6
0
3221225684
0
false
1
0
false
0
The last event:
Log Name: System
Date: 2018/11/10 17:25:51
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
41
6
1
63
0
0x8000400000000002
4004
System
0
0x0
0x0
0x0
0x0
0
0
0
0
false
0
0
false
0
We hope Intel can advise what should be done other that uninstalling and reinstalling as that didn't help.
The power supply is stable and on UPS.
I am having the exact same issue with a NUC8I7BEH that I set up this weekend.
Windows 10 Pro, latest BIOS and all latest drivers.
When display goes to sleep there is no way to wake it up again.
Currently have all sleep settings turned off.
I have the same problem.
I tried to find what happened after the was turning off so I played music to see if system was still running.
The result is very disappointing. Sometimes the system stopped responding when I moved the mouse to wake up the machine. That means the music stopped and the hard driver led went off. Sometimes the system hung when the screen went off.
The only way for me now is set screen always on.
I have been complaining about this issue since the 4th generation NUCs (yes, 4 generations - and 4+ years - ago!). Intel has *never* implemented a reliable fix for this issue...
Update: I did some test and see whether it is hardware/drivers issue or OS issue. I install a linux OS Fedora 29 workstation version. All drivers are up and running by default. But, but.......
When the screen is off, the whole Linux system will auto reboot. So I have to set the Screen Idle time = Never.
So, I conclude this is not the problem of Windows/Linux or so call compatibility issue, but the problem from the hardware/drivers themselves.
I disabled Realtek audio device in Device Manager. Seems the screen can be woken up now.
I am not sure if all of you can use this solution but you can have a try.
Computer Management->Device Manager->Sound, video and game controller->RealTek(R) audio
right click->Disable device
Disable audio device can't solve this problem completely.
There is another thread about random reboot issue under Linux. I believe it is the same problem.
You can try solution in this thread:
/message/592827# 592827 https://communities.intel.com/message/592827# 592827
It also worked but i still need more time to verify if it can solve the problem completely.
I had the same problem. The light on the unit stayed on after powering off. It dit not turn on. I had to long-press the power-button to really power it off. So I could turn it back on again.
What I did was simply remove the power suply for a few seconds. After that, it's fine, but not sure for how long.
Try to wake the screen up from the keyboard by pressing Ctrl+Win+Shift+B. That should restart the graphics driver. That's the only thing that work for me (different NUC model but I hope it works for you too).
I had been doing some test, at begining i think is an issue of windows but not, its from graphics driver (I hope that)
only put never automaticaly put turn-off in never and sleep in whatever time.
Maibe this fix whit futere bios update or driver version.
I am seeing the same issue. This is very frustrating. Disabling the Realtek Audio device did not help.
- NUC8i7BEH
- Windows 10 Pro (1809)
- Latest drivers, latest BIOS (0048)
Hi, you can try the solution in another thread.
I just copy it here:
boot:
no secure boot
no boot from optical, LAN network, or thunderbolt
power:
no wake from LAN or t.bolt
turn off PCIe ASPM Support
turned on native acpi pcie support
With this solution, you won't experience this issue every time the screen goes off. But you still have chance can't wake up the screen.
I used this method for some days and there was one time the screen couldn't wake up. The hard disk LED is OK and the keyboard is usable but the screen is off. I tried to use control+win+shift+b to wake up screen but there was only a beep. Anyway, this solution works most time for me.
PatOnEarth, thank you for linking the other thread!
Sadly, if there is still a chance of this happening again it is no solution. Any time it happens I might lose my work, which is not a risk I am comfortable with.
@Intel staff reading this forum: Is this issue being investigated?
I update all drivers with driver pack solucion and the proble appear will fixed, but in few that I will check it.
Same issue here. If I put it to sleep manually, computer wakes up without any problems.
Called Intel tech support, they suggested replacing RAM and SSD.
I am pretty sure it something that should be addressed with BIOS update.
FWIW, when this problem occurs for me (3-4 times since purchase) it is always when I have my WD 1TB "My Passport" drive connected to USB. No problem when that drive is unconnected.
Curious coincidence: most recent release notes for BIOS of another model (NUC5) says:
Fixed issue where system hangs during POST when Western Digital
1TB MyPassport external USB drive is connected.
