Intel® NUCs
12102 Discussions
NUC8I7BEH W10 PRO - USB 3.1 ISSUES
FZ1
Hi, I have issues when i connect HDD or SSD with USB 3.1 Gen 2 interface to the NUC8I7BEH. Windows 10 does not recognize the device, and there are many USB errors in the event log. I tried with different devices and i have this issue only with 3.1 gen2. With USB 3.0 interface it is ok. Windows Drivers are all ok and OS is Windows 10 Pro 1809, Windows update it's updated also. Is it a common issue or just mine? Thanks to all.
LeonWaksman
Hello @FZ1​
  1. Your NUC should support USB 3.1 Gen 2 devices. Please refer to paragraph 1.6 of Technical Product Specification https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7...
  2. You should ensure that not only Windows O.S. and Windows driver are updated. Please check if you have the latest bios and latest Intel's driver installed as well: https://downloadcenter.intel.com/product/126140/Intel-NUC-Kit-NUC8i7BEH
  3. Special attention you should give to chipset driver https://downloadcenter.intel.com/download/27998/Intel-Chipset-Device-Software-for-Intel-NUC-Kit-NUC8... and to Management Engine Driver https://downloadcenter.intel.com/download/28095/Intel-Management-Engine-Consumer-Driver-for-Windows-... . Without this two driver installed, Windows can not correctly recognize your hardware.
  4. If your bios version is older that the latest ver 0056, you may download BE0056.bio file https://downloadcenter.intel.com/download/28394/BIOS-Update-BECFL357-86A-?product=126140, save on USB fully formatted to FAT32 and update your bios using F7 method https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html
Hope this will help
Leon
FZ1
Hi, i have latest win 10 pro version, latest driver, bios, chipset and intel me driver downloaded from Support intel page correctly installed but if I plug a device usb 3.1 gen 2 the device don’t work and I find many usb errors in the system event log. If I connect same device to the nuc but across a old 3.0 hub the device work limited at 3.0 speed but work and I have no errors on the event log.
IFu
Mine doesn't even work with USB3.0 lol. I can write to the portable disk but it was really slow to read from. Using the back USB type C port with a connector works though.
Alberto_R_Intel
FZ1, I just wanted to check if you need further assistance on this matter or if the problem got resolved? Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
Alberto_R_Intel
FZ1, Is there anything else we can help you with? Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
FZ1
Hi Alberto, i'm sorry for delayed reply.
I' had tried a another NUC8I7BEH anche got same error with usb 3.1 gen 2 with my usb storage devices both with usb c and usb A.
So... i buyed other devices and finally i connect a USB NVMe disk with no error and crystal disk mark sequential test go a 940Mbps over USB !
The devices that wasn't work are :
and device that work a 10Gbps and no USB coonection error are:
Devices that have not worked are manufactured by manufacturers that usually release reliable and performing products.
I have no idea why they give errors on 2 different nuc8i7
 Thanks again for support
Alberto_R_Intel
FZ1, No problem at all, thank you very much for providing those details. We will do further research on this matter, in order for us to be able to do that please provide the SSU report: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility To attach the report, once you choose "reply" select the "clip" icon located on the lower left corner. Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
Alberto_R_Intel
FZ1, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter? Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
Alberto_R_Intel
FZ1, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question. Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
