Intel® NUCs
Assistance in Intel® NUC products
13311 Discussions
NUC8I7BEH specific input dc voltage
iMea
NUC8I7BEH Offically Input DC 12V-19V(±10%)
so,
is 10.8V-20.9V the specific input dc voltage?
I have a power bank that outputs DC 10V-12.6V 150W Max
Is it possible to operate the nuc8 with the power bank?or how min voltage can operate the nuc8?
n_scott_pearson
Super User Retired Employee
That's just barely within tolerance. When you take tolerance of battery into account, you suffer failures regularly. No, you need 12V with 10% tolerance. Better if higher. Get yourself a buck converter and fo it properly.
n_scott_pearson
Yes, it is possible, but I would make sure that you set it to output at its highest voltage.
When people ask about running on batteries, I always recommend that they look into getting a DC-to-DC "Buck" Converter, which can convert the voltage to 19V and eliminate any drift. Here is an example of such a device (one that was developed specifically for NUCs): Mini-Box.com: DCDC-NUC, 6-48V automotive power supply for NUC, 12V or 19V output.
Hope this helps,
iMea
thanks for reply,
could you tell me the specific input dc voltage?
n_scott_pearson
Anything between 12V and 19V. 19V is best.
iMea
n_scott_pearson
iMea
It works fine, off 12v is okay
