Community
cancel
Showing results for
Search instead for
Did you mean:
NLapl1
NUC8I7HVK AMD Radeon driver unusable
Jump to solution
Just got a new NUC8I7HVK. I installed every driver and the last one is the AMD Radeon driver downloaded from the NUC support page.
While installing, the screen goes black and then starts flickering, maybe once each 2 seconds. After rebooting, the flickering continues. The driver is absolutely unusable. Upon uninstalling the driver (between the flickers), everything goes back to normal, but I'm stich with the generic VGA driver. I'm connected via an HDMI cable.
Tried upgrading BIOS to latest version 40 and resetting bios to defaults, but the problem persists.
Windows 10 Pro not activated yet (problems getting activation from old NUC). All Windows updates done. Windows version 1803.
I'm a bit disappointed right now. Anyone can help?
NLapl1
Well the problem was the combination of HDMI cable an monitor. Tried the NUC on a full HD monitor via the same HDMI cable and no problems. Tried the NUC on the problematic monitor via DP and no problems. Sorry! Problem solved.
Community Manager
Hi
Got problems with Radeon driver but Win 1803 helped me.
Maybe advices from my case will help you
Thank you
DGard6
Win 1803 fixed my problems with the Radeon driver as well.
NLapl1
