Intel® NUCs
12111 Discussions
NUC8I7HVK - displayport not working
RWils5
Recently purchased the NUC817HVK with is now up and running. I also purchased a Samsung 4k freesync monitor at the same time.
I found out to use freesync that I need to use displayport rather than HDMI. However when I connect the displayport I don't get anything on the display, it looks like it is connected as it doesn't show no signal but nothing shows up.
Have tried different resolutions/refresh rates etc but no luck. Any help appreciated.
LeonWaksman
Please download and install Intel System Support Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Download Intel® System Support Utility for Windows* . After installation of this utility, run it and perform system scan. Save the generated report and attach the txt file to your post.
Leon
RWils5
System Support scan attached
LeonWaksman
HellpArtfulnz
1. Please download and install Chipset Driver : https://downloadcenter.intel.com/download/28217/Intel-Chipset-Device-Software-for-Windows-10-64-bit-... Download Intel® Chipset Device Software for Windows® 10 64-bit for the Intel® NUC Kit NUC8i7HNK, NUC8i7HVK
2. Please download and install Management Engine Driver: https://downloadcenter.intel.com/download/28215/Intel-Management-Engine-Consumer-Driver-for-Windows-... Download Intel® Management Engine Consumer Driver for Windows® 10 64-bit for the Intel® NUC Kit NUC8i7HNK, NUC8i7HVK
Leon
RWils5
I installed both the chipset driver and the management engine driver (why doesn't the intel update software install these???) and it made a small difference in that I could see the screen for 1/2 sec. I decided to get a new cable to see if that would fix the problem and thankfully it did.
Thanks for your help.
PS When I did the original install I had display problems with HDMI and wasn't able to resolve until I disconnected the CMOS battery as per your suggestion in another post, so thanks again. Not sure why you need to do this with a brand you piece of kit???
