Intel® NUCs
12113 Discussions
NUC8I7HVK randomly switches to a blank green screen and then back to normal over and over. What is wrong?
WCote
Just purchased NUC8I7HVK, the display switches between a normal view to a blank green screen and back again. This happens randomly. I can correct by pressing the power button to put the unit to sleep and pressing the button again to wake it up. I have all the latest drivers installed and the BIOS is up to date. The unit is running Windows 10 Pro.
LeonWaksman
  1. How are connected to the monitor (interface type)?
  2. What is the model number of your monitor?
Leon
n_scott_pearson
Super User Retired Employee
This kind of issue is typically caused by poor/bad cable. Please answer Leon's questions plus: What is cable being used between the NUC and the Monitor? Are any dongles/adapters included in the path?
WCote
The NUC is connected to a Yamaha RX-A720 receiver and the RX-A720 is connected to a Samsung UN55ES6500 to HDMI 2.
I could recreate the problem by turning the receiver off and on.
I then used a different HDMI cable and I could switch the receiver off and on and and the problem did not happen, but after about an hour playing a game it started happening again. Right now I'm using the different cable the problem has not occurred.
There are no dongles/adapters involved.
n_scott_pearson
The better the cable quality, the better the result. You get what you pay for...
