Intel® NUCs
12121 Discussions
NUC8i5BEH – Ethernet port does not work
ASull3
I'm using Windows 10 Pro (64 Bit), the most recent BIOS (0056) and driver version 12.18.8.4 for the "Intel® Ethernet Connection (6) I219-V" but the Ethernet connection does not work.
I also tried different patch cables, reinstalled the drivers, but the Ethernot port does not react at all, it keeps saying "Not connected".
The cisco switch tells that there is no i/o at all:
Previously I've used the NUC7 on the same Ethernet connection, no problems with it.
Alberto_R_Intel
ASull3, Thank you for posting in the Intel® Communities Support. For this scenario, we can try to un-install the driver from device manager, select "Network Adapters", right click the LAN driver and select "Uninstall", then please try to install the Intel® Ethernet driver version 23.4: https://downloadcenter.intel.com/download/28096/Intel-Gigabit-Ethernet-Network-Connection-Driver-for... If the problem persists, we can try to install the Intel® driver version 23.5.1: https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=... Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
ASull3
Thanks for answering. I already tried that but it didn't work so I sent the device back to the retailer. I have now to wait for the replacement NUC.
Alberto_R_Intel
ASull3, You are very welcome. Perfect, thank you very much for letting us know those details. Any other inquiry, do not hesitate in contact us again. Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
