Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13499 Discussions
NUC8i5BEH : M.2 SSD is not shown for installation Ubuntu target drive
melonsode
I bought NUC8i5BEH and M.2 SSD.
I tried to install Ubuntu 18.04 LTS.
But M.2 SSD is not recognized for installation drive.
I checked visual BIOS and I found the M.2 SSD is not shown for boot priority tab.
I already have updated BIOS to BE0077.bio (latest).
I need help. Thanks in advance.
SSD: ADATA technologhy, SX8200PNP M.2 2280 PCIe Gen3x4 SSD / Supports NVMw 1.3 , LDCC ECC, S.M.A.R.T
melonsode
I have succeeded to install Ubuntu.
The issue is not BIOS configuration.
I added optional parameter for ubuntu installation and it words.
param: nvme_core.default_ps_max_latency_us=250
See a link below .
linux - NVMe: missing or invalid SUBNQN field - Unix & Linux Stack Exchange
https://unix.stackexchange.com/questions/470778/nvme-missing-or-invalid-subnqn-field
See also
Windows 10搭載のPCにUbuntu 18.04.3 LTSをインストールし、rEFIndを利用してデュアルブートする - Qiita
https://qiita.com/asaken1021/items/bbac6b7e828b4d40eb20
LeonWaksman
  1. Remove and reset the SSD again in its slot. Check that is sitting in the slot up to the end and is fastened by the screw.
  2. Set the Bios to default settings. While in Bios press F9 followed by "Y" and then F10 followed by "Y".
Leon
melonsode
I removed the SSD.
I set the SSD again.
Then we can see the SSD connected in "SATA" tab and " PCI" tab.
But we can't see the SSD in "Boot priority" tab.
I need more help. Thank you.
melonsode
I did reset BIOS to default.
melonsode
See a link below .
See also
LeonWaksman
  1. I can see that your SSD is recognized in Bios (SATA and PCI tabs).
  2. You can't see this drive in Boot Priority tab since it isn't bootable yet. The O.S. is not installed.
  3. The NUC8i5BEH is not supported for Linux by Intel . Only Windows 10 64 Bit is supported https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html . So, you need to get support in Ubuntu forum.
  4. Those are links to the pages that may be will help you: https://ubuntu.com/download/intel-nuc-desktop and https://help.ubuntu.com/community/UEFI
Leon
