Intel® NUCs
Assistance in Intel® NUC products
12957 Discussions
NUC8i7BEH SanDisk Extreme 400GB A2 not recognized.
EHall12
I recently purchase an Sandisk Extreme 400GB A2 Micro SD card from Amazon. It worked in my Compulab Fitlet 2 under Mint Linux, but will not work on the NUC under Mint, or CentOS 7. The OS comes back and says Error -110 which means card defective. I have re-checked with other machines and it still works fine. Is this a BIOS support issue, or other NUC hardware compatibility issue?
Card is
SDSQXA1-400G-GN6MA SKU 6 19659 16569 7.
n_scott_pearson
Super User Retired Employee
According to the Compatibility site, the largest microSDXC that has been found compatible is 256GB. I cannot find any place where they document a maximum size, however. Intel Customer Support will need to ring in here if they know of any limitation.
EHall12
So I found a slower 400GB SanDisk MicroSD card, and the nuc recognizes it just fine. Wonder if there is a diffrence, I'm sure there is. It sure would be nice to use the faster card for a staging area when backing up with Amanda etc.
Wanner_G_Intel
Hello EHall12, According to the Technical Product Specification > Section 2.2.4.5 Micro SDXC Card Reader, the board has a micro Secure Digital (Micro SD) card reader that supports the Secure Digital eXtended Capacity (SDXC) format, 3.01 specification https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7BE_TechProdSpec.pdf We found that the Secure Digital eXtended Capacity (SDXC) format, announced in January 2009 and defined in version 3.01 of the SD specification, supports cards up to 2 TB (2048 GB). Version 3.01 also introduced the Ultra High Speed (UHS) bus for both SDHC and SDXC cards, with interface speeds from 50 MB/s to 104 MB/s for four-bit UHS-I bus. Capacity > SDXC https://en.wikipedia.org/wiki/SD_card "SD Part 1, Physical Layer Simplified Specification, Version 3.01" (PDF). SD Association. 2010-05-18. https://web.archive.org/web/20131205014133/https://www.sdcard.org/downloads/pls/simplified_specs/archive/part1_301.pdf NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there. Based on the product specifications for SDSQXA1-400G-GN6MA, it should work with your unit. However, this specific Micro SDXC Card has not been validated or tested by Intel, so we cannot guarantee that it will work as expected. http://compatibleproducts.intel.com/ProductDetails?prodSearch=True&searchTerm=Intel%C2%AE%20NUC%20Kit%20NUC8i7BEH# If you are still unable to use this Micro SDXC Card with your unit, the operating system could be the cause. Intel has not validated Mint Linux and CentOS 7 on this product. You can review the Supported Operating Systems for Intel® NUC Products below. If you can test the Micro SDXC Card in a Windows* 10 environment, please let us know your feedback. NUC8i7BEH - Windows 10 (64-bit) https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html If you are using the latest BIOS and drivers for your unit, and the issue persists, our recommendations are that you can use the latest kernel and contact your Linux vendor for further support. -Linux* Operating System Vendor Websites https://www.intel.com/content/www/us/en/support/topics/linux-osv.html -Downloads for Intel® NUC Kit NUC8i7BEH https://downloadcenter.intel.com/product/126140/Intel-NUC-Kit-NUC8i7BEH I hope you find this information helpful. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello EHall12, If you have any further questions, please let us know. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello EHall12, If you need any further assistance, please contact us back. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
