I have the memory installed correctly and the harddsik. USB Boot Stick created on the Microsoft website. While trying to install the Windows 10, I can enter the key code but then I can not select a drive where it should install Windows 10. I then looked in the BIOS and found that no SSD is available. OK, I have the new BIOS 0056 installed but also no SSD visible afterwards.
What am I doing wrong or what else can I do?
I know Intel does not have this SSD on the list but if I am on the website of Crucial this SSD is called compatible with NUC8i7BEH.
Do I have to buy another SSD now? If so which would you recommend me -> M.2 SSD?
After you are entering the Product Key, delete all existing partitions, till you will see one unallocated space. Now press on Next and the installation should continue.
Leon
Thanks, I'll try it.
Marc
