Intel® NUCs
Support for Intel® NUC products
12125 Discussions
NUC8i7H*K Replacement Fan - CORRECTION
MLevi
Valued Contributor I
Completely edited this post .
Sorry - I need to research this more. I can't delete this original.
LeonWaksman
Hi Mike,
It is very nice, however it is not clear how to order the L.H. side or the R.H. side blower. See the attached image from my NUC. The blower having the same model numbers, but sum identification are different. Both fans are mirror images.
Leon
MLevi
I've completely edited the original post, and I appreciate your response.
LeonWaksman
H Mike,
If you will click on the image I've attached to my post, you will open it on your screen and you will be able to see the all numbers (above the word ELECTRONICS an also on the label with barcode. However it must special Intel order. I wish, Intel should sale them as a spare parts (those and the blower for other NUCs).
Leon
