Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11994 Discussions
NUC8i7HNK has two LAN ports...
npizz
can I I use one to receive internet from a router, and the second one to "send" internet to another device? (which is supposed to be a Samsung Dex station)?
Thanks!
n_scott_pearson
Super User Retired Employee
Of course you can. If you want only point-to-point communications with this station, you can easily do so using static IP addresses. If you want the station to be able to use the NUC to access the Internet, however, you will need to support the NUC being a Router as well.
Hope this helps,
