I just got this NUC and it cannot boot from USB 3.0 flash drives. I updated BIOS to the latest version (0053 from here: https://downloadcenter.intel.com/product/70407/Intel-NUC-Kits), but that didn't fix the issue.
Same drive works fine once OS boots, and also works fine in BIOS through USB 2.0 extension cable.
Similar issue to this: https://forums.intel.com/s/question/0D50P0000490XEkSAM/nuc6cayh-cant-access-to-usb-30-flash-drive-af...
Given that a year has passed since the issue was first reported, is there a solution now?
Thanks!
Hello UL000
Thank you for posting in the Intel Community.
Can you boot from that key in a different USB port?
What is the format of the key? Is it NTFS or FAT32?
We have been working on a similar behavior on the following thread
https://forums.intel.com/s/question/0D50P00004AR1MK/nuc8i7hvk-usb-efi-and-a-bootable-device-has-not-..., I have test different USBs and operating systems booting form the USB 3.0 (frontal blue USB).
Hope this helps.
Leonardo C.
Indeed it boots from a different port! It boots from all ports EXCEPT front blue one. It still boots fine from front blue one if using USB 2 extension cable.
EFI partition is FAT32. I was using stock ubuntu image for testing: https://www.ubuntu.com/download/desktop/thank-you/?version=18.10&architecture=amd64
The key is Patriot Supersonic Rage 2 (https://www.info.patriotmemory.com/supersonicrage2). It's capable of connecting using USB 3.1 Gen 1.
Thanks for suggesting different ports. This is not a huge issue anymore.
For more complete information about compiler optimizations, see our Optimization Notice.
